OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
THANKS VERY MUCH THIS IS SO CUTE ANSWER
thanks......right answer
thank you for answer
WHAT THIS HEATER COIL TO SET MY CANNON IR 3300 MACHINE
Canon ir4570 has error code E000100-0001
ERROR CODE E000002 IR 2545
Fix the fix'n
Canon 3300 error codes E000002-0000 in my printer pls help mi
SOURCE: MY CANON XEROX MECHINE MODEL:
my xerox machine is problem error code : E000002-0000
PLS help me i solve the problem
What will be the solution of Canon IR 3300 Error E000002-0000
(conon 1r 3300)turn the main power swich (on the main unit right said)off and on again. ifthe machine still does not operate normally,contact your service representative with the erorr code below. E000580-0000
(conon 1r 3300)turn the main power swich (on the main unit right said)off and on again. ifthe machine still does not operate normally,contact your service representative. SHOWING ABOVE STATEMENT. BUT WHAT NEXT ACTION TO CLEAR IT. CANNON IR 3300/2200 MACHINE ERROR CODE IS E000002-0000
