Question about Oregon Scientific DS9810 Digital Camera
Trigger button will not work therefore unable to take any pictures?
  • 42 Answers
Shutter-release button is small tactile-switch which lasts quite long. Please have it check if there's any other problem else?
Posted on Feb 14, 2008
Ingition key will not turn
I had this problem and the fix was some type of trigger in the ingnition module was bent or out of place. This trigger is only to make a bell ring when doors are open and the key is in the ignition. What happens is the key doesnt fully engage with this trigger bent in the ignition module, therefore it will not turn. I had a locksmith come fish the trigger out and everything worked fine, except the warning bells. I've learned to live without them.
Aug 07, 2011 | 2007 Chevrolet Uplander LS Minivan
Unable to reset the time on the timer it keeps flashing all the time therefore i am unable to use the oven
hold the first three buttons down , then using the last two buttons , set the time, oven should now work
Jan 17, 2011 | Belling DB2 Dual Fuel (Electric and Gas)...
I **** it back and then hit the trigger and it won't fire... it rotates the barrel and after about a minute or so of pulling the trigger rapidly it will fire. i want to be able to shoot normally and i did...
The factory must have left out a certain spring I could only explain to you if you've modded it.
Well, I'm going to explain anyway-
When you pull the trigger there is a mechanism is triggers that releases the plunger system, therefore compressing the air and firing the dart out of the turret. The factory (as I said before) left out the spring that makes the part move up or down as the trigger is operated, therefore making the gun malfunction.
My best suggestion- get a spring and add it in (if this is the case). Open up the shells/casing of the gun by unscrewing it apart and find the orange part next to the trigger.
Please email me at dluzzio@gmail.com a picture of the inside of your gun so I can analyze it.
If all else fails, take it back to the store.
Dec 30, 2010 | Nerf Maverick Blaster
It says that i unlocked different guns in the game after i got certain kills but i cant use them in the levels an di want to use them can you help me?
1. First you must unlock new weapons by completing hunts. Once you have unlocked a new weapon it will stay with your hunter into all future hunts.
2. Go to Main Menu > Aim at Mission Select and pull trigger.
3. Scroll through all unlocked missions > Aim at any mission you want to hunt that is already unlocked and pull the trigger.
4. Before choosing which animal you are going hunt on that mission: Look at the bottom of the
"Hunt Select " page, there are Capitol Letters inside of white boxes. Each letter belongs to a different button on your Wii remote or Nunchuk. > Press only the button on your Wii remote or Nunchuk that will open: Select Firearms
( This letter is C on the top shot style, indicating the round button located right above the trigger on the Nunchuk )
5. If you pressed the right button the next page will have a picture of a weapon with three box choices at the bottom: RIFLE - HEAVY RIFLE - SHOTGUN. > Aim at the box choice you want and pull the trigger.
6. This page has pictures of all the unlocked weapons in the category that you chose. Scroll through the pictures and choose your new weapon > Aim at that picture and pull the trigger.
7. The next page will have a picture of the weapon that you chose. At the bottom of the page you will see two options: Select Firearm or Back > Press only the BACK button on your Wii remote or Nunchuk.
8. You are now back at the " Hunt Select " page. Choose which hunt you would like to go on, > Aim at that hunt and pull the trigger.
9. When that hunt opens you will be carrying your new weapon. HAPPY HUNTING!
Dec 26, 2010 | Activision Cabela's Big Game Hunter for...
"Menu / OK" button is not functioning.
Your ribbon strip that connects the keypad to the main board has either come loose or more commonly has started to break on 1 of the 2 folds in it.
Only real solution is to have it replaced
Jan 11, 2010 | Fuji FinePix F470 Digital Camera
I cant get left trigger to work without pressing really hard,help
The plastic inside may have snapped a little and therefore not long enough to properly reach the little button on the logic board, shake the ds a bit and listen out for any ratling noises. The button might not be centred properly, worst case is that the button on the logic board may have a dry joint and is coming slightly loose.
Jan 06, 2010 | Nintendo DS Lite Console
When taking photos of moving items, sometimes it talkes a long time to expose and therefore I get pictures of the ground/sky etc
many cameras have a slow shutter release .. when you push the button you expect it to take a picture right away .. but the camera has to first adjust for focus and determine how much light is or will be available then set itself up .. this takes time but some newer cameras do it all very quickly .. one way to get around this is to first hold the shutter button down half way .. do this early just before your subjects are where you want them .. the camera will auto focus and set itself up .. keep the trigger in that half way position until the subject is in place .. now when you push the trigger the rest of the way down, there is very little lag ... make sure that you focus on something close to where your subject will be when they are in position .. .. another speed up trick is, if your camera has manual focus .. preset the focus for where you want it and that saves the time it takes to auto focus .. there are several digital camera reviews on the interent ..they will tell you how much shutter lag you can expect for different cameras .. that can be a great help when you are ready for a new camera or want to see where your present camera performs ..
Jul 13, 2009 | Olympus SP-560 UZ Digital Camera
My Zune 80GB MP3 DIGITAL PLAYER
try to restart it or whatever try clicking The arrow button then up on the keypad. make sure you downloaded the software. and updated.
May 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
Unable to access files on the flash drive
SDHC cards are not backward compatible with normal SD cards..therefore older devices will not recognise them...your built in card reader is probably not sdhc...try downloading directly from camera or use a sdhc usb card reader
Apr 29, 2008 | PNY 4GB Secure Digital High Capacity...
Oregon Scientific DS9810 Digital Camera Logo
35 people viewed this question
Top Oregon Scientific Cameras Experts
Fabrice Wolters
Greg Cann
Greg Cann
Computer Links
Are you an Oregon Scientific Camera Expert? Answer questions, earn points and help others
