said modem supplied by BSNL with broad band connection for my home PC.is there any software required to run the same.please note modem configured by BSNL.but with out any software.from where i will get drve software?
-   where we collect this modem's driver for USB? -   Guest
Jul 22, 2008
-   run cd , not able to detect usb
-   Guest
Jul 22, 2008
-   do not run even after driver from cd (supplied )are installed
-   Guest
Apr 15, 2008
-   Recently BSNL has installed Siemens ADSL modem C2110 insteed of my Hwai modem. The main problem is that in the pack of Siemens modem C2110 they have not provide any list of spars supplied alomg with the modem e.g. Splitter, Cable with RJ11, Software etc. that makes the BSNL authority to conseal the technology, they used to configure the same very flicky manner resulting user gets lots of problem while connecting even user unable to configure it as per his needs. The autodialing configaration also not disclosed/ provided by BSNL autority.-   walktime40
Mar 13, 2008
-   While connecting the Siemens C2110 ADSL modem its driver and configuration does not exist in our system. How can it install on the system for using a broadband connection?-   DCKNJ
try 192.168.1.1 with login: admin password: admin in internet explorer. Hope of some help but be careful to make any chnages untill and unless you undertstand each and every thing.
Following is a link where you can get USB modem driver installation guide and driver.......but please make sure that you do not try to install this on SERVICE PACK 3.......because that will not install on service packs.........in case you have service packs for XP installed first uninstall ther service pack........then install the USB modem which is more or less smooth........and you can reinstall service packs afterwards without any conflict later on after the installation is complete.........this is the way I was able to install this modem driver on my PC.......
Using BSNL Braodband with Siemens C2110 ADSL Modem does very good in
the first 15 - 20 mins but...
(More)
the first 15 - 20 mins but after that i cant browse the net also cant
display the sieemens setting while browsing 192.168.1.1 .
But if i keep for about 15 mins in power off mode, and start again it
works for 15 mins and continues the same problem,,, please help...
software?
Uanble to get webpagesby the drivers as provided by CD by BSNL,namely Lan iad. Tried more then 100 times. 1 or 2 times did get a page or 2 but couldnot repeat the same next day. How to proceed now.
