Question about Kenmore 22422 Top Load Washer
Kenmore 90 series will not agitate or spin
Checked the motor coupler (intact, replaced it 1.5 yrs ago) and lid switch (intact, responds to being depressed by screwdriver).
Agitator/basket will attempt to spin, but fail within 5 seconds. Buzzing sound ensues, if left, will trigger the circuit breaker.
Visual inspection shows no oil under the chassis.
Thanks in advance for your ideas!
  • bubbaMcBubba
    bubbaMcBubba Jan 16, 2008
    Looks like you called it, Catriver.
    SWMBO (She Who Must Be Obeyed) must've been washing some pillows--the pump ass'y was lousy with polyfill. Got that fished out, reassembled, and it looks like it's working fine now--though I guess I should wait to see if it drains and spins fine, too, before I rest on my laurels.
    If you're ever in the Durham, NC area, I owe you a couple of homebrews. The washer rests in my brewcave (basement) so the fruits of labor can be appreciated simultaneously.
  • hakimis Jan 22, 2008
    Can anyone tell me where the instructions are and how to fix the will not spin issue? We just noticved it last night...please email me the info at [email protected]
    President:
  • 878 Answers
Bubba, before you get into the spin tube, brake or clutch, this sounds more like you have something caught between the basket and tub or you have something jammed in the pump. First check that out and post back. Catriver.
Posted on Jan 16, 2008
  • Ron Marek
    Ron Marek Jan 16, 2008
    Good work Bubba, my son lives in Charlotte, so I might take you up on that, see if you can come up with some Texas medicine or railroad ginn....Catriver
6ya staff
SOURCE:
Replaced Kenmore 90 coupler - now NOTHING works!
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The first and easiest question is: Did you remember to re-connect the Lid Switch???
If it still won't agitate or spin, I'd check that the Motor coupler was installed correctly and hasn't destroyed itself.
I'd also test the switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
May 31, 2010 | Kenmore Washing Machines
I have a kenmore 90 series washer that won't spin. It makes a grinding type noise at that point in the cycle. I followed the trouble shooting guide and checked the motor/gearbox coupler. The coupler looks...
If the coupling is OK then the problem is most likely to be further up the drive-line, which means the gearbox has probably failed. .........Nomess
May 16, 2010 | Washing Machines
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
Agitate/Spin Issues (again)
if your coupler is good change your agitator dogs that will fix slow wash and clutch on top of transmission or lid switch for no spin
Nov 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series will not agitate, spin
Check for something stuck between the basket and tub, otherwise you probably have an internal gearcase problem.
Jan 16, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 22422 Top Load Washer Logo
244 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
