Question about D-Link AirPlus DI-524 Wireless Router
DI 524 On computer boot up message reads Missing file,wianapi.dll I can't figure out how to reinstall. Thanks
  • 2 more comments
  • cinbor Jan 18, 2008
    Got a reply but not one idea to fix the problem.
  • nenne Jan 27, 2008
    I have the same problem with the missing file when a start the computer. Using "Vista".... maybe that will cause the problem... i donĀ“t know,
    Jens... please help!
  • o4isabel May 20, 2008
    Yea. The same thing with me. I can't find where to diwnload the file wianapi.dll. Thorleif
  • Fin1000ale May 11, 2010
    How do I reinstall wianpi.dll to the Dynamic Link Library as well as thw procedure entry point apsinitialize??? Thanks
Can't connect to my DI-524 router??? Help
Posted on Jan 18, 2008
Wlanapi.dll error 1628 on 3.8 64 bit single processor and d-link adaptor and router on cable lan
this is a dynamic link library error . means that the wlanapi.dll is missing.
2. uninstall the router program and reinstall
3. check the trash to see if you have deleted this file. If so restore immediately.
4. do not empty trash bin you may have other dll files in there. If deleted will render your Windows inoperable.
5. this file is the file that load the wireless features in the router.
May 17, 2011 | D-Link AirPlus DI-524 Wireless Router
Acer Aspire One Netbook D260A.Windows XP not booting. Message Reads Windows could not start because the following file is missing or corrupt. Windows Root System 32 Hal dll No recovery disc or USB...
Sometimes you can get the needed .dll file online, and manually place it on that drive, of course in the correct directory.To do this, you need a functioning computer and you hook up the hard drive with the problem VIA USB. You can get USB Hard drive adapters from most retailers.
You may want to extract all data before you do anything, just in case. Have you been doing backups????
Usually, you reinstall the OS to resolve this issue, but without disks, not so easy to do.
Feb 03, 2011 | Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
May 08, 2010 | HP Compaq 6720s Notebook
C:\windows\system32\hauurjab.dll is missing on my
Just google the error msg and you'll find the solution for it. At most times, ppl recommend you to delete this particular registry file that is associated with this dll file. But if I were you, i would better reinstall the operating system. Just google the error and give a try. Best o'luck.
Hope this helps, If so, rate me.. ,thanks - billa
Sep 05, 2009 | Microsoft Windows XP Home Edition
Hal.dll file missing or corrupted
Follow the steps given in the link below to troubleshoot the hal.dll missing issue:
Aug 26, 2009 | Microsoft Windows XP Home Edition with...
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Air GCFG.exe-find aps Get Interface Count in DLL-file wlanapi.dll
>> AirG-CFG.exe-find aps Get Interface Count in DLL-file wlanapi.dll This is a software error on your computer, not on the D-Link router. Uninstall the software for the wireless adapter on your computer. Reboot. Reinstall the software.
Apr 28, 2009 | Microsoft Windows XP Professional With...
Missing dll since XP sp3 has been installed
It means : SP3 introduced a new wireless lan application programming interface (windows program that interacts with your wireless card/device driver)
solution : check your wireless device or computer manufacturer for updated (works with SP3) driver.
Aug 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Winxp cannot boot - missing files message
probably corrupted operating system files. i'd suggest doing a fresh reinstall of windows xp. if the problem continues then get a new hard drive.
Dec 27, 2007 | Computers & Internet
Just make sure you get these files on your computer.
Download hal.dll from here:
Place it in windows\system32 folder.
Now go to the drive you have windows installed in (C:/ for example), and then create a new file, name it boot.ini.
Open boot.ini with notepad, and enter this:
[boot loader]
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS /usepmtimer
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Save boot.ini now, and try booting your computer, it should work.
Nov 17, 2007 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
83 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
