Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Cord to use for installation
The installation instructions say to connect using the "cable of your choice".  How do I know which one to chose?
    Champion:
  • 207 Answers
Is there any option cables highlighted during the installation? check your cable what you are using right now..
Posted on Jan 16, 2008
I lost my instructions to hook up my printer to my computer i have a canon mx310.. i need to know which phone cord goes into the computer and printer?????
I hope this installation/setup guide will help you [Click Here]. If I am right, you don't need a phone cord to connect the printer and the computer, but a USB cable. If it's in case of Fax, you would need the phone cord to connect the line to the printer/fax machine.
If you need further help, let me know.
Good Luck.
Thanks for using FixYa.
Jan 23, 2011 | Canon PIXMA MX310 All-In-One Printer
How to connect our printer to our computer
disconnect printer from computer -- prepare two cables and drivers -
(USB cable and power cord, along with CD software drivers )
install s/w (software) by inserting CD in drive bay -- allow for auto run to occur
install drivers , follow instructions.
when prompted connect power cord to printer and to Ac wall outlet, then connect USB cable to computer
continue following onscreen instructions. printer will be installed automatically and will be recognized by computer
send me 4 thumbs up please.
Jan 11, 2011 | Epson Office Equipment & Supplies
Dome camra wire connection with bnc
Preparation
Before installing your RCA camera scout the area and confirm that you will be able to run the cable from your surveillance digital video recorder (SDVR) to your camera. You may want to use RG59 Siamese cable, which is a single cable system with three wires: a coaxial cable for the video and a positive and negative wire to provide power to the camera. If you are installing your camera outside, place it at least 10 feet high to minimize tampering, or put your camera in a dome or other protective housing.
Coax Cable
BNC connector
BNC connectors and cable image by Albert Lozano from Fotolia.com
BNC connector
If you use Siamese cable to wire your RCA camera, you will run the cable first, and then install a BNC (bayonet Neill-Concelman--named for the inventors) connector on each end of the cable. BNC connectors vary by manufacture; install the BNC connectors according to the connector instructions. To get a general overview of the process, see the Resources section for a video on installing BNC connectors.
Power Wires
Plug with standard lamp-type cord
element electric power black image by Leonid Nyshko from Fotolia.com
Your camera came with a power supply with an integrated power wire; the power supply plugs into a standard wall outlet and the other end plugs into your camera. The cord is probably not long enough, in which case you will have to cut it and splice the Siamese in the middle to deliver power to your camera. The power supply wire is designed like a standard lamp cord and must be cut in half and split. One of the wires will be marked with a stripe, a series of dashes, a rib on the insulator or some other marking (just like a lamp cord). The marking indicates that this is the positive wire. After cutting the supply cord, connect the portion with the camera plug on it to the Siamese cable at your camera and then connect the power supply portion to the other end of the Siamese cable near your SDVR. The positive (marked) power supply wire should be connected to the red Siamese wire and the other wire connected to the black Siamese wire. While many people use wire nuts to connect the wires, connecting the wires with a wire beanie (see Resources) will provide a higher quality installation.
Plug-and-Play
Plug-and-play cables make it easier for homeowners to install their cameras. These cables incorporate all three wires into one cable system and come with connectors preinstalled so that you will not have to install connectors or cut wires. This is slightly more costly than assembling your own cable, but it will save you time and you will not have to purchase special tools to install the connectors. Run your plug-and-play cable and connect it by following the instructions which come with your cable. See the Resources section for a video on installing plug-and-play cables.
Dec 16, 2010 | Dome (8) Cctv Dome Color Ccd Night Vision...
How to install brother hl-5250dn to windows xp
Fist uninstall all the drivers ralated to the printer, then install it again.
1. Turn off the computer
2. power cycle the printer
3. Turn On the computer
Aug 12, 2010 | Brother HL 5250DN Laser Printer
Cant connect to laptop (only shows desktop no playback)
if u r connecting a laptop to an external monitor...just connect the monitor cable to the monitor jack in the laptop and u need to make changes to the display in the control panel...
Control Panel/Display/Setting tab/Advanced/Monitor or Display Tab...there u will get the choice to send the signal to either the monitor or laptop display...
chose and freez the choice....
Dec 14, 2009 | NEC MultiSync FE700 17" CRT Monitor
How do i connect my lexmark x5470 with out cd software
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Jun 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can not down load any part and have a disk
You need to install printer software from disk distributed with the printer before connecting the printer USB cable.
Apr 15, 2009 | Lexmark X2600 InkJet Printer
TiVo installation
Since the Series2 doesn't do HD, you don't need any fancy connections, and it's pretty simple to hook up.
1) Disconnect the cable that's connecting your cable box to your TV, from the TV end.
2) Connect the end that *was* connected to your TV, to the "input" on the Tivo.
3) Get another piece of the same cable (coaxial cable), and connect the output of the Tivo to the input on your TV.
That's it.
You may just need to go to Best Buy and get a piece of coaxial cable to connect the Tivo to the TV.
Dec 15, 2008 | Tivo Series2 Digital Video Recorder...
Cable coxail
It is the RF input into the tuner......repair choices are...
1) Replace / resolder original connector
2) Install new connector
3) Replace tuner-provide make & model for part # of tuner
Please rate this solution....................
Nov 14, 2007 | Mitsubishi WS-55511 55" Rear Projection...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
57 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
