Question about Amana NDE2335AY Electric Dryer
Dryer not drying
I have a Amana NDE2335AYW Electric dryer that is only about 2 years old. there was a water leak in the laundry room and ever since my dryer has started to act funny. It will get extremely hot and smells like it might be burning something but will never dry a load of clothes. I dried a single load of clothes 3 times and was still not dry. I checked for a clog and the air exiting the vent outside was warm and forceful. What could be wrong with it and how do i fix it? Thank you Stefani
  • Anonymous Mar 28, 2014
    Hi, laundry doesn't get dry. You can have it spinning for 2-3 hours but to no result. I think the air actually doesn't warm up to dry the laundry. Easy to fix or ask for replacement? It's an EFE118A. No clue how old it is. It's been standing outside since they got it, I presume. Hot, humid Singapore.
    Thanks,
    President:
  • 1,314 Answers
Try taking a flashlight and look over the back of the drier see if the vent got mashed or is all coled up and stuff let me know also you can remove the vent from the back of the drier and run 1 load to see if it works normal if so then you know the vents the culprit.
Posted on Jan 16, 2008
Loud noise from dryer
Good Afternoon,
If a toothbrush went into the dryer it would have to remain in the drum. There are no outlets large enough for a toothbrush to fit through. Can you tell where the noise is coming from? Also, check the drum good, the toothbrush could be hiding behind one of the ears in the drum and you probably can't see it. Try running your hand behind the ears inside the drum, it just might be there! I hope this will help you and thank you for using FixYa!
Mar 22, 2009 | Amana NDE2335AY Electric Dryer
Dryer heat output is 148, but takes several runs to dry clothes
You most likely have a ventilation problem somewhere in your exhaust line. This can be very dangerous and a fire risk. You need to do a thorough check of your vent pipe and make sure it is clear and the exterior trap door is working freely.
Jan 26, 2009 | Amana ALE643RB Electric Dryer
Amana Model NDE2335AYW Needs a Jump push to get started drying. Have so far been doing this by lifting the top and pushing the drum
That means that your motor is going . I'm not sure how much your willing to put into it but that tends to be kind of expensive. good luck
Jan 11, 2009 | Amana NDE2335AY Electric Dryer
Installing a drum belt on an Amana NDE2335AYW
call me if you'd like and i'll walk you through it Jim 417-926-0106
Dec 20, 2008 | Amana NDE2335AY Electric Dryer
Dryer problem
Your problem may be associated with heavy accumulations of lint inside the dryer and/or ducting. If you have had a water leak recently, and the dryer ducting got wet, the lint could be sticking somewhere and forming a clog. A simple way you can determine if you have a clog somewhere is to disconnect the dryer vent hose from the dryer and start the dryer. The air leaving the dryer should be forceful and about 140 degrees (in other words...good and warm). If the air is weak and cool, you have a clog somehwere INTERNAL to the dryer. If the air is forceful and warm, check your ducting from the dryer to where it exits the house. A dryer needs proper air flow in order to dry properly. The fact that your dryer is getting very hot tells me that the heating element is heating up, but may in fact, be OVERHEATING. The dryer will not continue to run in this condition. Eventually the heating element or thermal fuse will blow. Take the time to perform these simple steps and post back with your results and/or comments. If it is not a simple clog, I can give you further advice on how to determine a cause of your problem.
NOTE: If you plan on cleaning the dryer interior, ensure you unplug the dryer from the power source. Live voltages of 220VAC are still present even with the dryer turned off.
Jan 14, 2008 | Amana NDE2335AY Electric Dryer
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Amana Dryer NDE2335AYW
Found my problem. The 3 prong unit on the cord connecting at the dryer. One of them was melted. Glad my house is still standing.
Dec 05, 2007 | Amana NDE2335AY Electric Dryer
Amana NDE2335AY Electric Dryer Logo
235 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
