Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon ip3000 After changing the black ink tank for the first time......the unit will no longer power up.....nada. Jeff
  • Anonymous Jan 23, 2008
    My Canon IP3000 stop printing black. I put a new black tank in & still no black printing. What next?
  • 2,427 Answers
Try putting back in your old cartridge, If it works it means your new cartridge is defective or is not an original cartridge.. Newer printers have an upgrade in the firmware to detect Generic compatable cartridges or refilled cartridges and they claim the fail safe is to prevent damages to your printer.
Posted on Jan 16, 2008
I refilled my canon pixma ip3000 black ink cartridge and now the black will not print. Can you help?
Canon 3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Jan 14, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Nov 04, 2009 | Canon Office Equipment & Supplies
Black won't print. Changed all ink cartridges,
It may need a new purge assembly, if it doesn't clean both sides properly either color or black will quit. You might try a new printhead first, QY6-0064-000 around $40.00
Jul 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Will not print.. cannon pixma ip3000
Ink has dried in the printhead. You need a new one, QY6-0064-000, around $50.00
Jun 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Black ink
Hi
Check out my reply to chengfrank43 in ip3000 section.- it may be of some help to you.
Feb 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I CHANGED MY PIXMA INK CARTRIDGE AND HOW TO RESTART?
Here's what you can do....
METHOD #1 - Easiest, but it disables the ink tank level indicators.
1) Ignore the low ink indicator, and press the RESET BUTTON to continue printing. If you press and hold the reset button for 5+ seconds, it will disable the counter for that particular ink tank. Refill tank now.
2) Repeat as needed.
You will get a dire warning that this will void you warranty, blah blah blah. If you do need to take your printer in during warranty and you've disabled ink tank counting, simple reset the entire printer as describe below for the wate tank warning, and nobody will ever know. SAVE YOUR CANON CARTS with a bit of ink left in- your printer will need to have Canon carts installed for warranty service.
3) Eventually you may be warned that the tank is empty. Press reset as above to disable and continue printing.
If you think this entire thing is ridiculous- you are right.
Get an earlier model that takes un-chip carts, like an ip6000, or ip3000, or i960. Much simpler and you get to use the ink tank indicators after refilling.
You can reset the entire printer with the WASTE TANK reset (below) when you need to clean or change the waste tank PAD (its really not a tank) See the above instructions for the i960 and similar for other Canon printer waste tank changes.
Here's the ip4200 reset options:
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power
in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Nov 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Ink not mixing properly, Magenta is taking over
return p/head and get a new one.it may b contacts in machine
Jan 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer not printing
Try a new tank, there are more and more people getting bad ink tanks. HOWEVER if it is a printer that has seperate heads you might have to change it.
Sep 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
old marine
old marine
