Question about Acer Aspire 3680 Laptop
Battery back up is limited to 1 hour only
After buying my brand new laptop on feb, 5th 2007 battery was delivering power for 3 hours but since last 2 months when i start my laptop it shows only 1 hour, if i continue to work on it it suddenly get power off after 35 to 40 min.
    Problem Solver:
  • 6 Answers
I would suggest you discharge the battery fully by using the laptop and then let it shut off. Then freeze the battery in the freezer overnight for at least 12 hours. Yes i know it sounds stupid but it works. Then after you have taken it out. Let it thaw out in just a room with normal room temp. Make sure you put the carrier bag underneath. After about 3h - 4h thawing time. Then make sure there is no water or any liquid visible. Finally put the battery back in and charge for the recommended charging time when you first got the laptop E.G. 10hours. It worked for mine and restored the battery!!!!
Posted on Jan 16, 2008
  • Amarjit Singh
    Amarjit Singh Jan 24, 2008
    Did this work them?
  • 58 Answers
Did you do a full cycle charge when you got the Laptop? When you buy the Laptop you have to use the computer on battery till the battery dies and then charge battery for 12 hours and you repeat that another time. Most likely your battery it is damaged. Maybe you call the company and they might replace it for you.
How long should it take to recharge my iphone 4 brand new battery ?
The first two or three times, don't look, but normally, when you use a 1 A (1000mA/h) charger, within 4 hours. I don't like to use the iPad charger that can deliver 2 Amps, because it will heat up the battery. And the wormer it gets, the sooner you need a new battery.
But, if you want to find out the quality from your battery, just visit the genius bar in an Apple store. They test it for free, and also can point out if there is an app consuming too muck power. I went in with my iPhone 4 and they found an older firmware version. They put in a newer firmware (not the iOS) and since then it is running 2 or 3 days with one charge, with a 4 years old battery. Before I went in, the battery would drain in less than 6 hours.
Sep 30, 2014 | Apple iPhone Smartphone
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
I bought an acer timeline x 4820 tg laptop 1 month ago which says it has got a battery backup of 8 hrs but it doesnot even gives a 5 hour battery back up . why?
The only reason is it will depends on the usage of your laptop. You can try to change the power settings of your computer so that it will last for more than 5 hours. You have 3 options: Power Saver, Balanced and High Performace.
1. Go to Control Panel
2. Hardware and Sound
3. Power Option
Thanks for using Fixya.
Jan 24, 2011 | Computers & Internet
Compaq EL81 laptop. Battery will not charge. Laptop powers/boots up with battery installed but shuts down after a few minutes. Removed the battery, power up and unit now stays on. Bad battery?
The battery in my laptops only seem to last 1 or 2 years.
Yes, I would say it's a bad battery.
Try to get a higher capacity one from amazon.com. I upgraded from a 6 cell (1 or 2 hours of battery life) to a 9 cell (3 or 4 hours of battery life) on my Acer Aspire for about $39.
Prices will vary depending on make and model and capacity.
Aug 17, 2010 | Compal EL81 Notebook
Hi my battery only lasts up to an hour, how do i
Well it should last between 3-4 hours if new. <br /><br />Batteries need conditioned . You fully charge them and then run them fully down. 1 hour seems pretty short. As a rule, don't run them on battery while plugged into power.<br /><br />I have no better solution than this.<br /> <!-- from fixya rte -->
Aug 17, 2010 | HP Pavilion zd8000 Notebook
Dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Mar 15, 2009 | Dell Computers & Internet
Battery not running
Possible that whoever replaced your battery sent you the defective one back. Note the serial and model numbers on the battery, then request another one. When you receive the replacement, do a full recharge. Most new batteries come already half charged. Even in this state, take time to fully charge it (between 4 and 8 hours depending on the type and model). Then try running it on battery power. If the charge holds more than 2 hours on a new battery, youre good; less than an hour new, its defective. If after all of this still not resolved, request the company honor their warranty (usually a limited one year with purchase).
Mar 01, 2009 | Dell Inspiron Desktop with Intel Core 2...
How much time laptop should normally run on fully charged battery in good condition
This varies from laptop to laptop, when new a it should not run less than one hour (that is with heavy use), I have seen some brands run as long as 3 hours (top end models)
Jul 01, 2008 | Computers & Internet
Columbia Telecommunications Group 2-way watch - battery needed
A close but not a perfect match....
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820***
Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820.
Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times.
This Li-Ion based battery provides power in a thin, short and light package, fits the compatible
Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking
for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry
for getting.
Features:
* Battery Type: Standard Li-Ion Battery(Model: RD43048)
* Capacity: (600mAh)
* Voltage: 3.70 V
* Talk time: 3 hours. Standby time: 3 days.
* Color: black
* Dimension(L*W*H): 4.6x3x0.5mm
* Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
Jun 17, 2008 | Columbia Telecommunications Group FRS 22...
Battery
yes buy new battery they usally make 2 differt ones low capsity hi ones that last 2 hours and oothers last 6 hours more cells 12 cell over a 8 cell one ok buy the better one
Jan 23, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3680 Laptop Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
