It does have to do with your sensors. Funny but I am having the same problem, but luckily for me I was able to find my manual. Look at the sending and receiveing units that are the protective "eyes" installed at the bottom of the garage door rails. One sould have a bright orange light (sending eye) and the other should have a bright green (receiveing eye). If either is dim or flashing that is where your problem is. The manual says to loosen the wing nuts and adjust the units up or down until both lights burn bright. If either is dim, it means there is an intruption in the wiring some where(my problem). Hopefully this helps.
Im gonna ask the obvious first: is there anything blocking the sensor at all? even a tiny bit?
The instructions in the owner's manual are correct, but after following them, my garage door installer and I discovered a few quirks and fixes for them.
It is important to park the Touareg in front of the garage door. Be careful not to park underneath it.
If your remote garage door transmitters are already programmed to your door opener, you need to do the following steps:
1. On the garage door opener itself, there is a learn button. Press and hold down the learn button until the learn indicator light goes out (approx. 6 seconds). (The learn button is near the antenna on your door opener.) By doing this, you have just reset the codes. At this point your remote door transmitters will most likely not work. This is o.k.
2. In the Touareg, press and hold whichever homelink button you want to program until the light above the homelink buttons slowly blinks. Continue to hold the button in and at the same time, hold your remote transmitter underneath the map lights and press the button. Continue to press both buttons until the homelink light rapidly flashes. Let go of both buttons.
3. You now have 30 seconds to press the learn button on your garage door opener. Press it once. The light will start to blink.
4. Go back to the Touareg, press and hold the homelink button you just programmed for 3 seconds until you get a blinking light. Repeat again. This time, it should open or close the door. The homelink button is now programmed.
5. Now that the homelink button is programmed, you now have to re-program your remote transmitters. Take the transmitters with you.
6. On the garage door opener, press the learn button, the light will blink. Now press the button on the remote transmitter. The light should stop blinking. Repeat the step if you have more than one transmitter. You should be all set. The homelink button should work in the Touareg and your remote transmitter(s) should also work.
In summary, the rolling codes in the door opener receiver have to be reset. For some reason, the Touareg has to be programmed FIRST. Then the remote transmitter units. If the remote transmitter units are already programmed, you will most likely not be able to program the homelink in the Touareg for a rolling code door opener.
Clear out anything previously
programmed into the in-car system from the factory by holding down
on the 2-outside buttons simultaneously, until the in-car LED starts
flashing rapidly. This may take up to a minute (in most cases, the
key should be on auxilary, and/or the car door must be shut).
Decide which button you want to
make to be your in-car garage door transmitter. Hold your
transmitter up near the selected button, pressing both the garage
door remote and the selected in-car transmitter button
simultaneously. Hold down on the buttons until the in-car, LED light
flashes rapidly. This sets the in-car remote transmitter to be your
garage door openers make transmitter, but you are not done. You now
need to make this in-car transmitter your personal transmitter.
3. Go to the
Learn Button on your garage door opener. The button is usually next
to the area where the floppy antenna is connected to the motor head.
With Genie it is most often behind the light lens, and an indicator
light flashes red when pressed. With Sears or Liftmaster
(Chamberlain) it is near, or part of, the terminal screw board, and
is a red, green or purple square button with a green, amber or
purple indicator light. Press this learn button momentarily. The
indicator light will turn on and blink if Genie or otherwise stay
lit. For Genie systems, go back to the in-car transmitter button you
programmed and press this button 3 or 4 times, or until the door
starts moving. This should set your in-car transmitter to your
garage door opener. For Liftmaster, Sears, or Linear Megacode press
and hold the in-car button you programmed until the garage opener
light flashes. Your in-car is now programmed to operate your door.
3. Go to the
Nothing blocking the sensor that I am aware of.
