Question about Whirlpool LSR7333 Top Load Washer
Putting it back together
I had to replace a hose on my washer, now I can't figure out how to get the clips back on to put everything together. They are gold go in through the top, they look kinda like a camel back. Any suggestions?
    President:
  • 878 Answers
Jacquee, they are going to hook onto the back panel and snap in, check this picture out...Catriverputting it back together - fd7bc24.jpg
Posted on Jan 16, 2008
Took apart the washer and dryer and need to put it back together...i have everything except where the clear plastic hose goes
Kristen-follow the hoses-water comes into machine at the water supply valves-hot and cold which go into the tub-then there is a drain pump which is connected to the tub via a hose-the out put of the drain pump is connected to the drain through the back of the machine usually at the bottom and this goes into your houses' drain-follow the hoses and you shall reach laundry success-cheers Denny
Oct 25, 2013 | Frigidaire FEX831CS Top Load Stacked...
Tip
How to fix your washer if it does not drain or spin
kenmore whirlpool,roper,kitchenaid,estate,inglis washer if it will not drain or spin,it's a bad lid switch,remove the 2 head screws,flip the top up,pop the 2 spring clip,unplug the lid switch,pull the cabinet off,remove the 2 screws under the lid,replace switch,put everything back together and your done,most times the model number is under the washer lid-mike
on Jan 31, 2010 | Washing Machines
Putting handle back together it was leaky , cant find place for spring?
not sure but i am sure that its job was to push the trigger/throttle back in place so this should help you figure it out, more than likely behind the trigger look for a small protruding post/groove that would keep the spring in place--- you have pics to show now? that would help--- good luck questions just ask
Mar 30, 2013 | Powerwasher 80012 Universal Pressure...
Motor turns but the tub inside does not rotate and leaves water in the tub
If the motor is humming, ,could be a frozen Pump. or worn, or broken Pump Belt. , and it could even be the transmission, If this a direct drive, I think it is, Now Direct Drive Motors use a small, Usually inexpensive, Direct Drive motor coupling. It wears out because it'a Plastic and rubber. One end connects the motor, the other end to transmission. They do tend to go out on older washers. You will have to remove the cabinet to replace it. Then Pry the two clips off the pump and pull it off the motor shaft. Push it aside, leaving the hoses attached. Next put the rubber portion back on the gear case, align it with one of the holes at the 12:00 Position, be careful putting it back in place. Also make sure you do not move the motors shaft. Put everything back in place on the top clip and bottom clip,connect your wiring harness, and put all screws back in place. I hope this helps you.
Oct 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
The water supply will not shut off
The air hose from the tub to the water level switch probably got pinched when you put the cabinet back on. Remove the console screws and raise the console. The plastic hose comes through the cabinet just below the timer. Reposition it and try again.
Aug 22, 2009 | Kenmore 24032\24036 Top Load Washer
Water won't stop running washer runs over will not agitate
It sounds like the fill switch is either disconnected from the detection hose, or broken.
To open the machine, press the spring clips inward with a butter knife or putty knife, and lift up the top panel. You may need a flashlight to see where the clips are, but they are in the crevice between the top panel and the front panel, on the left and right sides. Once lifted you should find a thin hose that leads from the side of the barrel to the switch in the control panel. Pull it off the switch and blow into the hose to make sure that it isn't clogged. Put everything back together, and if it does it again, you need a new switch.
Jul 28, 2009 | Maytag PAV2300 Top Load Washer
Kenmore washer
Yes I fixed my washer problem.
The washer was stopping before it would drain and spin. I would raise the lid and then close it back and it would start back up. So we figured the lid switch was broke.
Before you do anything you "unplug" the washer!
You have to pop the ends off the back panel with the buttons on it. Then you unscrew the 2 screws at the bottom of the panel and raise it up. Then you remove the brass clips that are holding the lid on. Then you move the whole washing machine cabinet out. My husband replaced the lid switch. Then we had to figure out how to get the cabinet back on right. That took some time but we did it. Then you repeat everything you did to take it off to put it back together.
The washer is working fine now.
May 18, 2009 | Kenmore Washing Machines
How do I replace the drive coupler on a Whirlpool washing machine
he took the cabnit off???...ok now kneal or stoop straight down,,always unplug unit..now your looking at the pump ,,theres 2 clips holding pump on 1 upper and 1 lower take a small screw driver and pry them off twist just a touch ,let pump hang dont remove ,,now your looking at the motor ,,it also have to clips but there longer and they have to screws holding them through front...take your 1/4 nut drive and remove,,if you dont have nut driver pliers will do just take your time..now reach to your right side of motor and disconnect motor ,,put a little pressure with your hand and pull straight out...take the motor clips off the same way you took the pump clips off,,now you should have 2 plastic couper and 1 rubber grommet...remove broken pieces than put 1 half the plastic coupling all the way on the transmission line it up straight then knock t in with he back of your screw driver use another tool to knock with..now put the other coupling on the back of the motor the same way..take the rubber grommet and put it on the transmission side,,you must look and line teeth up with hole since the grommet is on 1 coupling you only need to line up motor have,,,now take 1 motor clip and put the bottom 1 back before you put motor back let it lay on floor,,put the top clip close ,,now left motor and push to the tranny coupler now put back top clip...reverse to put together..
any question fell free to contact me
Dec 28, 2008 | Whirlpool Washing Machines
RE: Putting whirlpool washer back together
I would agree with you, it sounds like it isn't going back together correctly. When I put the cabinets back on them, I first make sure all 4 of the spades sticking up from the base are straight and not bent over. Next I grasp the hole the lid covers towards the front and lift and pull it towards me so the bottom of the cabinet is closer to me than the top. Next, I use my foot to push the bottom of the cabinet under the bar that goes across the base of the machine. Then I tilt the top of the washer back towards the machine. I wiggle the sides, until the cabinet seats into the spades coming from the base. After it seats properly, the clips should be lined up properly to be installed.
Jun 30, 2008 | Kenmore 24032\24036 Top Load Washer
Replacing drainage hose
You need to remove the two screws that hold the front panel in place. Remove the hose from the drain pump and pull it out through the back of the machine. You will need to release the clip that holds the hose in place where it exits the back of the washer. Important. When installing the new hose, ensure that you put it back in the clamps inside the machine or it will get caught in the pulley.
Oct 27, 2007 | Amana ALW480DA Top Load Washer
Whirlpool LSR7333 Top Load Washer Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal De
