Question about Samsung SyncMaster 550S Monitor
Opening monitor hai .. i wan to open ma monitor back cover ,, i tried but i failed because of some locking system in the top . ya i removed all screw . am using LG Studioworks 45v
  • Anonymous Aug 13, 2008
    I want to open my monitor's cover, but it won't open. I took the 2 screws off, and it just opened a little. the back cover won't open completely. Please, help me to open it.
  • 555 Answers
It's easy to open, just insert a flat screwdriver in each top slot and push it until it "clicks".
Complete instructions and photos at:
http://josepino.com/?open-samsung-back-cover
Good luck.
Posted on Sep 04, 2009
Muje lock kaise lagana h
sir mena phone lock reset kar hai to kaise hoga mere mobile model no s3500 hai mein pone lock lagey tha ma bhool jeya hoo
to ma isha kise open karu
Dec 10, 2010 | Samsung S3500 Cell Phone
How to open CRT samsung Syncmaster 753s. I tried to open, it have only two screw, i removed that, but not able to open it. reason behind to opening, some noise is comes as same as short ckt.
its easy actually..there r two locks on top of monitor. u can see minute space betweem backcover and front...insert any thin bt hard strip or pin and push them back simultaneosly pull back the cover.it would work
Aug 27, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Maytag front load washer Neptune MAH5500B codes FL and DO
There is an emergency access cord provided for the manual unlocking of the washer door and can be accessed by removing the dispenser bezel. Open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Once the bezel is removed, look for the nylon cord near the door lock assembly through the opening left by the dispenser bezel. Pull the cord away from the door lock assembly to pivot the mechanical opener and push the locking lever into the open position. Open and close the door several times then start a new cycle.
Check the door lock assembly if the problem persists and replace it when necessary. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Access to the door lock assembly requires the removal of the front panel, dispenser bezel, and lifting of the top cover.
Open the washer door and remove the two screws securing the door hinge and the front panel to the front shroud assembly. Do the same to the two screws on the opposite side of the door opening.
Disengage the front panel posts from the clips located on the face of the cabinet by grasping the upper part of the front panel posts and pressing in on the outer edges then twisting it inward. Once the front panel posts are released from the cabinet, tilt the front panel away from the cabinet and remove it.
Remove the two 5/16" hex-head screws securing the two top cover hold down brackets; one on each side. Swing the brackets to the outside to unhook it from the lip of the top cover then lift the top cover to expose the door lock assembly. Prop up the top cover to prevent it from falling back into position while accessing the door lock assembly.
Disconnect the wiring harnesses from the door lock assembly and the two mounting screws then rock the top of the assembly forward and lift it off the front shroud assembly.
Clean the wiring terminals and the connectors then reseat the connectors several times. Replace the door lock assembly when the problem is not resolved.
Install the new door lock assembly in reverse of the steps given above. Review the steps thoroughly for easy reassembly of the washer. Make sure the wiring harnesses are properly and firmly seated to the door lock assembly terminals. The door lock assembly is part number 22004435.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
How to open back cover of samsung 55v moniter
Read somewhere that you need to insert a blunt screw driver in the slots between the cover and the the top of the front cover and press down lightly. hope this helps...
Feb 01, 2010 | SAMTRON 55V 15" CRT Monitor
How can i open the back cover since it doesn't have any screws?
it has screws...check it..may b check at the top of ur monitor
Sep 28, 2009 | Compaq P 70 Monitor
How can open the monitor Body (Cover)
hello,
it seems that you open any monitor first time i suggest you to if any screw is not present then not to try to open and if screw is present then remove the screw and remove the base also. then see any lock present on the cover. pull the housing upwards and plz unlock the cover very safety and this you may remove the cover
thanks
ramesh722
Nov 13, 2008 | LG L1717S-BN 17" LCD Monitor
How to open the back cover of the LCD monitor
Hi..there,
It's seems you got a backling inverter busted. Need to replaced a new one or repaired it. To repaired you need to replaced a bad capacitors with a bulged on top of each caps. Not sure...just replaced all the caps...:) Ok! to open the back cover, there are 2 types to open it. First unscrew the 4 corner screws. If there are some... First type it from the back. After you had removed all the screws. Get a good grip on the bottom R/H side with both hands pulling as hard as you can on the 2 joints. 2nd type from the front bezel. Laid your monitor screen upward and placed a piece of clothes to proctect the screen from smudged. Used 2 hands to lifted up the edged of a bezel...do the same on the other side... After that just removed the screws...and that's how to open the front and back cover... Have a nice day!
Oct 13, 2008 | AOC LM729 17" LCD Monitor
How do I open cover of Acer AL2021 Monitor ?
This is a bit tricky, but not impossible.
1. Remove the two visible screws near the bottom. 2. Pull the plastic covers off the stand: Pull from the inside (nearest where the stand is attached to the monitor. 3. Undo the screws and remove the bracket. 4. Under the bracket is the final screw. 5. Try pulling the front off the back starting at the bottom. It'll require a little force. 6. Now you should be able to get a knife in to pull the rest of the case off. Leaver by pushing the front outwards and back inwards and the clips should come off ok.
Aug 06, 2008 | Samsung SyncMaster 550S Monitor
How to remove back cover of monitor
Here are the instructions to open the monitor:
"Don't kill yourself just to save some bucks"
Good luck.
Nov 04, 2007 | Samsung SyncMaster 550S Monitor
Problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Oct 10, 2007 | SAMTRON 55V 15" CRT Monitor
Samsung SyncMaster 550S Monitor Logo
377 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
