Question about Sharp AL 1631 Copier
Hi, i am getting an error L1-00, and there is a noise like some gears rubbing
Read other posted solution but dont see colored screw on machine. Could it be something else?
    President:
  • 2,072 Answers
Is the lamp moving when you turn the machine on?
It should move slightly when you first power on the machine.
If it doesn't, then look to see if there is a cable or belt broken by looking down under the glass.
The scan motor could have failed.
The lamp/mirror carriage may be hitting the side of the sensor assembly and not going into it.
If someone has cleaned mirrors recently, it is possible to get the screws in the wrong position and a longer screw is catching the carriage.
The detection of the lamp moving is the code.
Posted on Jan 16, 2008
How we can solved the hp lj p2055dn printer noise
Hopefully one of the first four suggestions helped you. If not if you could post more detail as to what kind of noise is the machine making: a grinding noise, a squealing noise, how loud is it. descriptions such as that would be helpful in diagnosing the issue. Without a description of the noise any of those first four posts could be relevant. The easiest thing to try first would of course be a toner cartridge I have experienced them many times making noises especially if they're aftermarket cartridges. Other than that grinding noises are typically fuser related in that machine, with squealing and high pitch noises the description of the noise is very important because it could be a fuse or it could just be dirt in a gear cluster rubbing on a shaft or it could be the laser assembly. Ireally hate to post absolute diagnosis without enough detail especially when it comes to you having to spend more money. Hope this helps.
Sep 24, 2014 | HP P2035N LaserJet Monochrome Printer
Gear grinding
Sounds like your Process Drive Assembly has broken its mounting posts and the gears are no longer meshing properly, causing the grinding noise. The drive assy is located on the right side of the machine toward the front. It is held in place with 3 screws. If you wiggle on the gear assy and it moves, then you should go ahead and replace the machine. This is not a do-it-yourself type of repair and should be left to a Xerox Certified Technician if you decide to repair the machine.
Jun 10, 2013 | Xerox Phaser 8550/SDP Color Laser Printer
My washer machine makes alot of noise when it get to rinse cycle
It is possible that the drum is rubbing about when it is in te high speed mode and so make the noise. It is always good to observe what the noise is all about as this can be visible from the bottom of the washer.
You need to check the movements with a manual turning of the motor and drum. This noise can be from the belts, the bearings, the suspension or as said earlier the rubbing of drum due to heavy load or poor damping.
If this machine has a gear box for high speed , check the motor and the gear box for low/dry lubrication.
Jan 25, 2011 | Washing Machines
Rubbing noise rear end but not all the time
Hi.Most scooters use a steel key in each rear hub to drive the wheels. These often get noisy. As the wheel turns the weight is put on the key and then comes of as the wheel keeps turning making a noise each revolution of the wheel. To repair remove the rear wheels and wipe a thin smear of grease onto the axle and key. This will reduce the noise. Hint, loosen the bolts holding the wheel on before raising the rear end to remove the wheels. If you place a support or block of timber under the machine, be careful of the motor brush holders.
Other noises could be gearbox gears worn.
Good luck. Neil.
May 20, 2010 | Invacare Supply Group Invacare Lynx Large...
No error messages, but there is a loud banging noise during printing that just started. Cannot locate the source.......
Could it be more like a clicking or grinding noise? That would be the swing plate assembly gears. Those gears connect the drive system to the fuser, driving the fuser gears. There is no workaround, it is a replace only. I would suggest contacting a service provider. The swing plate assembly has either a quick 15 minute fix or a tiresome and complicated up to 2 hour fix, especially if the screws get stripped out.
What happens is the fuser gears and the swing plate assembly gears bounce slightly, creating wear on the fuser drive gear and the swing plate gears. Over time they wear down enough that they start making noise and will eventually start causing jams in the fuser. If you notice a bunch of white dust that has an oily texture when you rub with your figures on the drive side of the fuser, that is the gear dust.
Apr 09, 2010 | HP LaserJet 4250n Printer
THINKPAD G41 Fan Error
Hi
Thank you for your query
You are right when the laptop first starts up it is the fan, if you are getting error message then it is the heat sink (fan on top of cpu) that will need to be replaced.
I would only recommend changing it if you know how as getting to the motherboard is quite tricky to say the least
Please dont listen to the geeks at bestbuy, they obviously dont know what they are talking about
If this has been useful please leave positive feedback/vote/testimonial - Thank you again
Feb 13, 2010 | IBM ThinkPad G41 Notebook
50.1 fuser error not fixed by instruction on machine; HP color laserject 3500
17 posts - 8 authors - Last post: 23 MarWe are getting a 50.1 fuser error with our Colour Laserjet 3500 printer ... fuser from HP in the UK, but was told that they are not currently available ... hi I have the same problem error 50.1 with two machine 3500/3550 ...
www.fixyourownprinter.com/forums/laser/31146
Dec 04, 2009 | HP Color LaserJet 3500 Printer
Disc Read error on original early PS2--ticking noise
Hi you will probably get constant disk errors because it is not the best console you can get. The older versions are now stopped being prossesed. My best bet is to get some rubbing alcohol.The spray doesnt really make an effect but will also make an effect.Im not sure what the effect is but your bets bet is to get rubbing alcohol.
If you have any further questions please ask me.
Thank you.
Mar 01, 2009 | Sony PlayStation 2 (PS2) Console
Washer making rubing noise while turning
On the back of your machine you can remove the back panel think it is about 8 screws. Once you get the back panel off look closely at the motor. Motor mounts, gears, clutch, brake, and if need be take the bottom apart and look at the main bearing on the bottom of the drum to make sure that hasnt gone bad
Feb 14, 2009 | Kenmore 24032\24036 Top Load Washer
Sharp AR-168S
check in the exit part of the machine, front edge there is a holding pin that may not be removed. it should just unscrew to release the scaner. (it should be blue or green).
Oct 24, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
82 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
