Question about Polycom Small ClassStation VSX 8000 (223022120001)
Help me I am tring to get get the mac address off my poly vsx8000 and i went through the intail setup process and when it rebooteed it gave me a blue screen that reads visual concert vsx but no main page or directoy after that, what could the problem be and how can i get back to directory to get the mac address?
Power on unit, press and hold * key on remote takes a few minutes but spinning polycom logo will appeara and a minute or two after that the menu screen comes up. Main output is configured for S-video, your seeing a 2nd monitor output, doing above will switch the VGA to be main output.
Posted on Feb 08, 2008
How to change admin username & password on cisco 2911 router
agree that turn off your modem first before trying to open the router's setup page. By default, there's no username and the password is admin on Cisco 2911
http://www.3anetwork.com/cisco-cisco2911/k9-price_p238.html
Nov 04, 2011 | Cisco 2911 Router
I recently installed a netgear wndr3300 router at my home. I went through the setup process with no problem, and everything checked out ok. But when i clicked finished, a screen popped up saying the ip...
If this is the case, the setup wizard detected an IP conflict between the router and the modem. It means that the modems IP address is in the same range as you router so it has to be changed. If the IP address of your router was changed to 10.0.0.1 , you should be able to connect to the internet. Try accessing the routers setup page by opening a browser and type 10.0.0.1 at the address bar. It will ask you for a username or password. Type admin for the username and password for password (this is the default settings). If it does not work try to remember if you already have changed the username or password. Once you are in, enable the mac clone option. Check if it works.
Apr 18, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
WRT120N Linksys router will not connect to Vizio Wireless Blue Ray Player. Need to lower the security to connect to Blue Ray Player.
If anything it's the other way around; the blue ray player needs to connect to the wireless router / access point. Can the blue ray player be configured to work with a WEP/WPA/WPA2 secured network? Check the owner manual or go through the setup menus to see if there's a way to set up a new wireless network and configure the password for your wireless network on the blueray player. The other thing to check is to see if the router is filtering based on MAC address. You can probably disable that feature without losing much security since MAC addresses are easily spoofed.
Mar 25, 2011 | Computers & Internet
(F5D6230-3) Wireless Router: i need to know how to change my mac address on my ...
In your browser's address bar, type 192.168.2.1.
By default, leave the password blank.
On the Belkin setup page, go to Internet WAN.Then go to MAC address. You may close your computer's MAC address or type a specific WAN MAC address, if required by your ISP.
I hope this helps!
May 16, 2010 | Belkin (F5D6230-3) Wireless Router
Netopia 3347 boots me off Interent
Hi! I will be more than glad to assist u in this concern..the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Aug 01, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Just bought a HP Laptop along with a Linksys WRT160N router. Currently have a Dell desktop w/service by local cable company. CANNOT get this router set up to get internet on the laptop. Help?
Hi! I will be more than glad to assist u in this concern..That is right! if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router ,u have to clone the mac address of ur dell desktop computer which works with the local cable company... normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just select on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem.
Jul 30, 2009 | Linksys WRT160N Wireless Router
Hi I cant configure my router D-link DIR-300
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 29, 2009 | D-Link DIR-300 Wireless Router
Bluetooth
the problem for that is the bluetooth mac address isn't setted properly or no mac address.i would i advice to send it back to them or you cam make your own bluetooth mac address.
Dec 11, 2008 | Samsung YP-T10 Digital Media Player
No audio or video on a VSX8000 to VSX8000 H.323 connection
Port Openings!! Check our website at www.vuports.com ... Look under the rental tab and at the bottom for a list of all port opening.s DAVID
Nov 30, 2007 | Polycom Small ClassStation VSX 8000...
Polycom Small ClassStation VSX 8000 (223022120001) Logo
364 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
