Question about Sub-Zero 690 Side by Side Refrigerator
Water comes out of the dispenser very slowly
When getting water from the door dispenser...the water comes out like a slow leak...rather than like a faucet. What is the problem?
Replace your water filter. It clogged up.
Posted on Jan 17, 2008
  • Charlene O'Dell Aug 20, 2012
    where is the filter? I can't see any filter above the unit. how do I open theplate at the bottom of the unit?
The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
Leaky dispenser-------
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
Kenmore 253.52632200 refrigerator water dispenser leak. The water dispenser in front of the door leak water slowly. Sometime it leak a lot and sometime it does not leak
You need to replace the water dispensing solenoid valve located in the back of the fridge and your problem will be solved.
Dec 12, 2010 | Kenmore Refrigerators
Water dispenser leak all the time how can i fix it?
May 10, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The door water dispenser leaks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Dec 03, 2009 | Frigidaire FRS26H5AS Side by Side...
I have 25 cu ft side by side with water disp and ice maker, still makes ice but water is not dispensing though door spigot,,no filter on the water and no leaks or bends in the water hose. Any ideas?
. If you don't hear the water inlet valve on the back of fridge, the dispenser switch is bad.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 23, 2009 | Refrigerators
My water dispenser flows very slowly. The unit is
Check for clogged output valve. Second the filter candles require an annual change as they also get clogged from filtering water.
Thanks for using fixya
proton
Aug 14, 2009 | Refrigerators
Water dispenser leaking at the door all the time.
Jul 09, 2009 | GE GSS25JFM Side by Side Refrigerator
Whirlpool ED22PE refrigerator in-door water dispenser very slow
remove the saddle clamp that some idiot put on the supply line under your sink and splice in a real "T" with a real cutoff. hopefully the saddle clamp is past your main valve and not before it or you'll have to turn off all your water first.
Jun 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Sub-Zero 690 Side by Side Refrigerator Logo
443 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
