I had this same problem, check the power transistors attached to the heat sink near the large caps, they tend to get cold solder joints after lots of heating and cooling. 15 minutes and good soldering iron will probably make a huge difference. I added extra cooling fins to mine to help dissipate the heat. hopefully wont go bad real soon again. Also check the large caps while your in there, maybe a good time.
I've been trying to figure out repair for my residential heating in Wasilla AK. I'm planning on just calling a place.
check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
