Question about Toshiba Satellite A135-S2276 Notebook
The screen still displays the image but the backlight if off
I have a Sony Vaio VGN-A690. When I turn on the laptop, it works fine. Windows loads and I can work. After a while, the screen starts to flash momentarily black. Shortly after the flashing, the screen goes black, not from it turning off but from the backlight turning off. The screen still displays the image but the backlight if off so the image is very hard to see. If I hook up the computer to a monitor, everything works great. What should I do to fix this problems.
  • 2 more comments
  • Vic121 Jan 16, 2008
    Thank you
    How get the inventor cganger out
    No warranty
  • Eejeej Dec 10, 2008
    As told in this item: my laptopscreen also turns dark (without backlight) but keeps working correctly. I have a HP Compaq NX6110. Please tell me what to do and what the costs might be in Euro.
    Thank you in advance.
    Eejeej
  • emmyarchy Jan 08, 2009
    Yes, i have the same problem, my compaq nx6110 laptop screen keeps going black, and coming back on with images. But if i connect a monitor to it, it works very well! Please what is the cause of this problem, and how do i get it fixed?
    Problem Solver:
  • 8 Answers
The problem is in fact the backlight as you are saying but i am not sure if it is the wiring to the power supply or if your backlight is just burning out. You can ask the company if you can send it in for them to look at it.
Posted on Feb 14, 2009
    Genius:
  • 1,601 Answers
You need to get the inverter changed out. Thats the part that changes DC to AC and powers the backlight
Posted on Jan 16, 2008
6ya staff
SOURCE:
Sony Vaio VGN A-690 no battery detected
Yeah. If when you take out the A/C adapter, the laptop goes off immediately, even though you have bought a new battery, then it's definitely some hardware issue with the laptop itself. I'd say just live with it as it wouldn't be worth getting fixed (cheaper to get a new laptop).
If it can run on battery fine, it's just that windows indicates that the battery is not detected, then it could be a software issue. But given it's the same in Windows 7 as with XP, this could be BIOS related. Perhaps try flashing the BIOS?
Oct 19, 2012 | Sony VAIO VGN-A690 Notebook
I need to know how to install a laptop hinge on a sony vaio a690? Is it required that I remove the lcd when I attempt to install the hinge?
As the hinge is what binds the display assembly to the laptop itself, you will need to remove the display assembly in order to replace the hinge. However, if you are only replacing the hinge cover, then you don't have to remove the display assembly.
Jan 09, 2011 | Sony VAIO VGN-A690 Notebook
My lcd is really bright then all these black blocks coming from the right going to the left no pictures, laptop works with a external ok. What am I looking for?
Please restart the computer and press the F2 key to access the BIOS setup. If the issue persist in the BIOS also then the issue is with the LCD screen, in that case service will be required to replace the LCD screen. You may either contact Sony Service Center at:
https://eservice.sony.com/webrma/web/index.do
Or you may also contact your favorite hardware vendor.
Based on the information, it seems that those are dead pixels and a LCD replacement will required.
The following are the Display part numbers:
A1062138A- Sharp Display Model# LQ170M1LA04
A8119991A - LCD Harness
468257801 - LCD Hinge (L)
468257701 - LCD Hinge (R)
468238001 - LCD Hinge Cover
147862922 - LCD Inverter
Thanks!!!!
Dec 28, 2010 | Sony VAIO VGN-A690 Notebook
How do you access the memory slot under the keyboard for a Vaio vgn-a690
Hi rmorrow002,
You can refer to the Computer model User Guide page number 175 to 183 for the detailed instructions (with images) to access the Memory Slots and Memory Modules in the Computer.
You can view and download the User Guide from the below link.
http://www.docs.sony.com/release/VGNA600series.pdf
Please follow the exact instructions in the User Guide. Removing the internal parts in the Computer may result series Hardware damages.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Sep 30, 2010 | Sony VAIO VGN-A690 Notebook
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
The screen fades out sometimes and i have to wiggle it to get it back. i have a sony vaio vgn-cr115e
www.ladparts.net
Oct 19, 2009 | Sony VAIO VGN-CR115E/P Laptop
My sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
Disassembly manual for sony vgn a690
generally only held in with small screw on the bottom of case right at the end of where the drive is. then it just slides out
Feb 24, 2008 | Sony VAIO VGN-A690 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
429 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
