Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Resolution Problem Yesterday my SyncMaster 204B all of a sudden didn't have a resolution option above 1024x768. I've always had it at 1600x1200. I have a dell inspiron e1505 that has 1280x800 resolution. I've never had a problem before. I don't know if I accidentally changed something or what, but I've talked to some people who tried updating the driver for it...didn't work. Any help?
  • 1,003 Answers
Re: Resolution Problem
TRY THIS: from your desktop right click on your mouse when drop down menu appears go to properties you will see display properties menu then select settings tab and adjust the sliding control to gain the desired resolution.
Posted on Jan 16, 2008
  • 58 Answers
Try to uninstall the driver and reinstalling it. Usually this is an issues with the driver or if have updated the computer with any other driver that might have caused the computer to have that problem. Check if installed any game or program that might have caused that problem.
Most of the time is an issue of an driver. Check on Device manager if there is any driver with a question mark yellow.
0 characters
3 Points
I want to set dafault menu setting for the resolution 1024x768 pixels
to set the resolution right click on your desktop then find the appearence option ,,you will find the resolution option there,,,
Oct 21, 2010 | Samsung SyncMaster 793DF (Silver, Black)...
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
How i can fix my 21.5" computer samsung monitor, the display is slightly stretched
Set your screen resolution to 1600 x 1200, the native resolution of the screen.
Oct 11, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Screen Resolution problem
Different video cards offer different ways to deal with a user's screen. ATI, and others, for instance, offer a "virtual desktop", which does what you're describing. You get to the settings that control this feature from the Personalize->Display Settings menu options. Here you'll also find the different resolutions your video adapter supports. If the 1600 x 1200 resolution is listed, then I would remove the existing driver for both the adapter and the monitor, and reboot the machine. On startup, Windows will most likely detect the "new" hardware (actually, your existing ones) and will go through the process of finding the appropriate drivers for your adapter. Good luck!
Jul 17, 2009 | Samsung SyncMaster 204B (Silver, Black)...
No 1440X900 Resolution Option in Display Settings
Windoze is not detecting the monitor correctly. Right click the desktop as you had before to get to the display settings. Click the "advanced" button at the lower right, on the next window, click the "Monitor" tab, and remove the check from the box from "Hide modes that this monitor cannot display". That should add to the settings the 1400 X 900 resolution you are looking for.
Jan 24, 2009 | Computer Monitors
Unclear Display
Goto cotrol panel/display/settings and set the resolution to 640x480. Make your you are using the video driver from the manufactorer for your video card. Windows generic drivers do not work well for all monitors. When you get the proper video driver you can reset your resolution back to a higher setting.
Apr 28, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Prob with screen resolutions
May I suggest working on the monitor itself before tackling the video card.
To my understanding, your monitor came with an installation CD that contain drivers/software for your OS to recognize the LCD correctly. Should you need a downloadable copy, its filename is 20050615115516359_SM740N.exe.
If you have already installed the monitor's drivers and updated your video card's driver as well, and problem persist, you may need to work on the AGP or PCI-E of the motherboard itself. Pls post back motherboard or PC's brand and model.
Hope this be of help. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
options listed would be correct for that monitor if you installed the drivers and inf file for the display. if it is another monitors resolution settings then you may just have the wrong monitor installed
Jan 30, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
117 people viewed this question
Top Samsung Computer Monitors Experts
Rugeshan Lanka
Rugeshan Lanka
Level 1 Expert
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Samsung Computer Monitor Expert? Answer questions, earn points and help others
