Question about T-Mobile MDA
Broken USB Port on T-Mobile MDA
Last night when I went to charge my MDA, I realized the USB port on the phone was broken and thus will no longer charge my phone. The rest of the phone works fine. How can I fix the USB port?
  • 9 more comments
  • JacqJacks Jan 22, 2008
    Thanks for the advice. I definitely want to try this as I have nothing to lose! What do I need to open the MDA up? It doesn't look like a phillips screw.
  • deepwave Feb 07, 2008
    my USB port is broken and I want to know how to open the cover of the phone to fix it. I've tried many times but didn't succeed.
    I tried unsrewing all the screws that I saw on the back but it still seems to be stuck.
  • Anonymous Feb 18, 2008
    how to repair t-mobile mda.
    website
    thanks for informtion!
  • ScrappleMan Feb 27, 2008
    USB port broke off circuit board. Looking for disassembly guide, eg: Where are push points, screws, etc.
  • lalakers May 16, 2008
    i was trying to charge my t-mobile mda and the usb port broke and got loose and doesnt charge........please please give me a solution just email me it.
  • Anonymous May 29, 2008
    USB PORT BROKE... WONT CHARGE...  ????
  • Anonymous Jun 10, 2008
    my usb plug wont broke off so.. i cant charge it grr... its problem after problem with the mda i am just gonna buy a new fone
  • bmwm3fn24 Jul 10, 2008
    my usb port on my MDA is broken...and i need to know how to fix it. when i try to plug it in the usb falls into the phone and when i pull the charger out the usb comes out with it. how would i fix this?
  • acolvin Apr 17, 2009
    I have the tmobile mda and my phone will not hold a charge anymore. I was told it was my charger port as well and I'm pissed!! I use my phone primarily for business and most of my valuable contacts & info is saved to the phone and not the sim. I need to get my phone charged so I can get all my important info out and I guess get another phone. H
    Where can I get this port fixed?
    Please help me!!
  • enrydimitri Apr 18, 2009
    my usb port is broken...
  • Anonymous Mar 18, 2014
    my blackberry wont charge i just fixed the charging point and went back to the shop that was fixing the phone they told me that i need to fix my software plzzzzzzzzzzzzzzz help dont know what to do even when i putit on charge i wont work
Http://rapidshare.com/files/73138701/Wizard_Service_Manual.rar
Use a T-6 Torx driver to remove the four screws and use a fine point soldering iron. Takes about 30 minutes to do it slow and carefully.
Posted on May 19, 2008
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Posted on Jan 18, 2008
6ya staff
SOURCE:
How do you charge the phone?
You can see a USB like port at the bottom center of the device. You can charge the battery by: • Connecting your device directly to an external power source. • Plugging the device sync cable into the USB port on your PC.
Feb 22, 2011 | T-Mobile MDA
Can't charge my i mate kjam
I recent4ly busted my mini-usb port and the phone could no longer take a charge or sync. I took a high res photo of the port and realized one of the pins was bent. I posted all about it with screenshots on what it looked like broken and fixed.
http://forum.xda-developers.com/showthread.php?t=412098&goto=newpost
Jul 01, 2008 | i-mate K-jam Smartphone
I have an T-Mobile MDA. I haven't used it for over 6 months, went to charge it last night. plugged in the charger and the blue power light came on, went to menu screen. Left the MDA charging upon returning...
Your first bet is to remove the battery and hold down the power button for 10 seconds, then replace the battery and try to turn it on.
Sorry I'm not more familiar with the model of phone you're talking about but this has worked for my old PDA's when they won't power-cycle correctly.
Jun 27, 2008 | T-Mobile Computers & Internet
Charger port on phone busted
I don't know what you want to hear. If the USB port is broken off, you will either have to get a new phone, or open it up and solder it back on. There are probably 4 "feet" at the corners of the USB port that broke lose from the board and you will need to reattach these. Alternatively, you could find the same phone on eBay that has a broken screen or some other problem that leads you to believe it has a good ESN and a good motherboard. Buy that phone and swap the entire board out. RadioShack has a good tool kit that works with most mobile phones, it's about $15.
Jun 13, 2008 | Motorola Mobility V325 Cellular Phone
How do i disassemble a t- mobile mda cell phone?
Hay Saeedm
check out this link
http://www.cellphone-repair-shop.com/HTCMiniUSB.htm
I have the same issue. i just dont know how to get the parts together
DDD
Feb 27, 2008 | T-Mobile MDA
Mda not charging
Either your battery is bad or your soldered contacts on the inside to the charger port are broken.
Jan 09, 2008 | T-Mobile MDA
T-mobile mda is not charging
i have the same problem.... may anyone help me.. it is not charging.. and not giving any sign of charging.. plz reply
Nov 14, 2007 | T-Mobile MDA
T-mobile mda usb port broken
try other USB ports on your comptuer and try it on another computer before trying to open it up
Nov 13, 2007 | T-Mobile MDA
MDA phone screen is scrambled with Lines
Marc1234: sounds like the backlight is out......possibly a software malfunction.....try goign to www.t-mobile.com/wmuprade to reinstall the software....if that doesnt work, contact htc or your service provider....you will need a replacement. if youre out of warrenty, it will be a lost cause....
Guest,: your USB port is broken, if you dont fix it yourself, you will need another phone.
Oct 17, 2007 | T-Mobile MDA
I need the data on my dead MDA!!!
Try to trickle charge it by hooking it up to the USB and then to your computer. Let it charge up a bit then try powering it on or charging it the regular way to charge it even faster.
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
Sep 23, 2007 | T-Mobile MDA
T-Mobile MDA Logo
668 people viewed this question
Top T-Mobile Computers & Internet Experts
Ekse
Marvin
Marvin
markpain
Level 1 Expert
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
