Question about Hotpoint HTS16BBMLWW / HTS16BBMLCC Top Freezer Refrigerator
Hotpoint Ref/Freezer mod HTR16BBMFRWW
How cold should my freezer get? The FDA says I should store frozen food at 0 or below. My landlord states that my unit is not designed to get that cold.
Helen Pearre
watugot
  • 290 Answers
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Posted on Oct 03, 2007
SOURCE: Hotpoint FFS70 fridge/freezer
water keeps appearing beneath salad bin we have checked to see that nothing has come into contact with back wall of fridge ,and we have used a straw to keep the defrost gutter drain hole clear but water still appearing beside gutter drain hole .
Posted on Mar 02, 2008
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
WeListen2You
  • 538 Answers
SOURCE: Hotpoint Fridge freezing the food.
thermostat is buried behind the walls of that unit, are you ready to run this one..takes quite a bit of time..but
will get the item, if you can supply the actual serial number from inside or back of that unit..
Posted on Oct 26, 2008
SOURCE: hotpoint fridge freezer green and red light on, switch offering 0
green and red light on.Have you got a solution
Posted on Feb 20, 2009
Getting ice inside fridge on the back I have ice Diamond rfb50 there are no controls to adjust how to solve the problem
First, I'm not a Hotpoint representative.
* Check your warranty. Call for support
* Contact;
* Website; https://www.hotpoint.com/
* Support; https://www.hotpoint.com/appliance-support/
* Contact USA; http://www.geappliances.com/ge/service-and-support/contact.htm
* Contact Europe; https://www.hotpoint.com/appliance-support/europe.html
*** The following is for information only.***
* The controls are there but is probably covered with food or ice.
* Remove food and packages from freezer and store in cooler or refrigerator side of your Hot point.
* Inspect area for "parts" that may have fallen off. (non-food items)
* Unplug unit. Open freezer door and allow warm air to circulate and melt frost and ice.
* DO NOT use ice pick or metal devices to forcably remove ice. Let it melt naturraly.
* Use a fan to blow air into freezer (keep the refrigerator side closed)
* DO NOT use a hair drier as it may over pressure the refrigerant or melt plastic panels.
* Continue melting all ice. Note water may collect at bottom or on floor. Wipe excess.
* Take the time to clean and wipe down freezer box. You may find parts or ID plates as you clean.
* If you locate labels or controls then set the control to the middle (mid range).
* Continue defrosting till no excess water drains to bottom.
* Feel along walls and back for cold. Walls should be room temperature and dry to the touch.
* There was a large ice build up in the coil and fan area. The defrost removed the ice.
* Note; defrosting may take 2-4 hours depending on house temperature.
* If no "parts" were found. Then power up unit. It may take up to 2 mins for unit to cycle on.
* Close freezer and wait 15-30 mins. Check if getting cold.
* Once cold then refill freezer. DO Not overload freezer.
* Check after 24 hours. Freezer should be below 32f or 0c
* Normal freezer after 48 hours should be about 0-5f or -10c
* Higher temps after 36 hours indicate problem with unit.
* Amazon supports Hotpoint parts; https://www.amazon.co.uk/Hotpoint/b/ref=bl_dp_s_web_3816975031?ie=UTF8&node=3816975031&field-lbr_brands_browse-bin=Hotpoint
* Hotpoint you tube site; https://www.youtube.com/channel/UCDP4GHPAfiVT5QWsumS7Fwg
* How to ID and check; https://www.youtube.com/watch?v=YPglk963cXM
* FFAA52P (official); https://www.youtube.com/watch?v=TYEid9P3_4k
* HMCB5050AA (official); https://www.youtube.com/watch?v=Lxlz5Er3Iwc
* CS1A250 (official); https://www.youtube.com/watch?v=bAC7r2Z_-6I
* NFFUD 191 (official); https://www.youtube.com/watch?v=kWnP1ZNgFw4
* Defrosting freezer; https://www.youtube.com/watch?v=1z_SNB95OE8
* Customer fix (frozen solid); https://www.youtube.com/watch?v=lj6Vcsvi2Cc
* Call support for additional advice.
Aloha, ukeboy57
Additional info;
* Customer review; https://www.youtube.com/watch?v=8hlUNY3QVmE
Aug 04, 2018 | Refrigerators
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
We have a Hotpoint FZ150P freezer and ice keeps forming at the back of the inside of the drawers, with the higher drawers being most affected. What is causing this and how do we fix it?
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 22, 2011 | Hotpoint Refrigerators
My fridge is running, the lights are working, the freezer is cold but its not cold enough for the food to stay frozen or the icemaker to work. Also, the fridge part isn't getting cold either.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help go here:
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 20, 2011 | Hotpoint Refrigerators
Hello, My Hotpoint FFA60 fridge freezer is freezing my food within the refrigerator compartment. I've cleaned out the drainage pipe. do you have any suggestions please? thanks for your help Kind...
Leo Ponder
imufo2
Sep 12, 2011 | Refrigerators
The fridge is acting like a freezer. all food items are getting frozen. what could be the problem.fridge " samsung - 2 door
Leo Ponder
imufo2
Sep 09, 2011 | Samsung Refrigerators
I have a hotpoint FFA71 fridge freezer. The fridge is fine but freezer isnt freezing, although food is still cold. HELP!
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 24, 2011 | Hotpoint Refrigerators
I bought kenmore trio bottom freezer 2 years old, everything works fine, until one week ago, the fridge part becomes freezer, it frozen all the food, even I set temperature to 45F on the fridge.
Leo Ponder
imufo2
Aug 22, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My hotpoint future rf175b fridge section is al ways cold or frozen fridge is not defrosting properly. any advice well. is it thermostat is not working or defrost is not working.
Leo Ponder
imufo2
Aug 20, 2011 | Refrigerators
Hotpoint refrigerator freezer(top) mod ctx18bacerww not cooling/freezing correctly. removed inside back panel in freezer compartment,found coils partially covered in frost, fan not blowing.. flicked fan...
Hi, fan may have stuck, but you could have a defrost problem, check defrost heater, thermodisc(defrost thermostat) and defrost timer. or excessive moisture, if your days are hot, or if you put hot foods in ref. could result in excessive ice build up. you can manually defrost it, by unpluging ref. for couple of hrs, until all ice melted. then restart. you make get excessive water on floor. be prepared.
Aug 02, 2009 | Refrigerators
Hotpoint HTS16BBMLWW / HTS16BBMLCC Top Freezer Refrigerator Logo
103 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
