Question about HP DesignJet 750c plus InkJet Printer
Error on display
I hav a problem with plotter HP 750c plus,its displaying error code 060309 i suspect a trailing cable ,is it?
  • 1 more comment
  • aamir_jee21 Sep 09, 2008
    I have problem 010030 Display error.Not move carriage
  • Anonymous May 13, 2009
    need a bail senser flag for 650c 36in plot help
  • Anonymous Mar 27, 2014
    passes selft test, but when a job is sent to the plotter, the display window toggles between "Processing" and "2% Complete"
  • HP Expert
  • 141 Answers
Either bad carriage or trailing cable if you've already tried new inks.
Posted on Sep 05, 2008
  • steve shroder Sep 09, 2008
    if none of those work then it has to be the electronics module
System error code 070010
07-00-10 error code refers to a drop out voltage warning,
basically this means something in the machine is shorting the power supply out,
the chance's are that the fault lies with the trailing cable where the laquer and white coating eventually wears down to reveal bare trailing cable connections which short to ground causing the power supply to temporarily shut down causing the formatter to display the error.
this is a very old model now and the chances of you being abble to order 'new' have allready gone. I would recommend upgrading to a newer model.
Nov 07, 2013 | HP DesignJet 750c plus InkJet Printer
Hp 750c Designjet plotter system error 010030 00070b20
This is a problem with one of three
  • Trailing cable
  • main PCA
  • carriage assembly
Jul 09, 2012 | HP DesignJet 750c plus InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
I just changed a paper roll in my 750c and now I am getting error 010033 00070ae3. any suggestions? thanks
This error means there is a loss of communication between the main board and carriage. I had this problem, and tried to re-seat the trailing cables. This is the flat ribbon cable that travels with the carriage. Having no luck, I trimmed the end of the trailing cable slightly, which allowed fresh material to make contact when pushed back in. Problem solved.
Jun 29, 2010 | HP DesignJet 750c plus InkJet Printer
I am getting an 060309 error code on a HP DesignJet 650. What do I need to have repaired?
Probable cause:
The optical sensor on the carriage has
failed to locate lines drawn during the
pen calibration routine. Reduce the
ambient light. If the media is not clean
and reflective, change the media. If
the lines are faint, replace the pens.
Clean lenses. Replace LED. Use the
Edge detect test, found in the service
menu, to help troubleshoot.
Jan 25, 2010 | HP DesignJet 750c plus InkJet Printer
Hp 750c plus System error 060309
Please take a look at this link and follow the instructions given there. Also relevant links here and here.
Hope that helps you to sort it out!
May 22, 2009 | HP DesignJet 750c plus InkJet Printer
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Out of media Design Jet 750c plus
u could try reloading the paper roll, i have had that prob, and had to reload paper. it always fixede it for me. good luck
Oct 14, 2008 | HP DesignJet 750c plus InkJet Printer
Partial plot
if connected via ethernet cable then i believe you have a bad network card, if connected via parrallel, then check to make sure the cable is not over 15 feet in length. also try to uninstall and reinstall the drivers on your computer as they sometimes become corrupt. Good luck!
Aug 17, 2008 | HP DesignJet 750c plus InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
394 people viewed this question
Ben Johnson
