Question about Whirlpool LGV4634JQ Gas Dryer
Admiral Dryer turn on and heats up but will not automaticly stop after its cycle
I started a load the other day and when I returned 4 hours later the dryer was still running, all of the clothes were really hot but it did not shut down. I have cleaned the lint trap and the exhaust stack any suggestions?
  • Dryer issues Jan 18, 2008
    I stack was cleaned three months ago, but what I found out last night is that a worker apparently damaged the stack while doing work in the roof and kinked the pipe pretty bad. I ran a load without the exhaust line hooked up and found that the dryer works fine. I replaced the damaged section of pipe and Now everything is going great, thanks for the help.
    Scholar:
  • 196 Answers
Did you have any lint build-up in the vent exhaust ? I need to know before we proceed.
Posted on Jan 18, 2008
  • Elmer Vest
    Elmer Vest Jan 19, 2008
    Glad to be of some service. Keep in mind that with a gas dryer any blockage in the vent will cause the heating system to shut down. When this happens the thermostat cannot cycle.
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Dryer suddenly stopped heating
Heating element, thermostat or thermal fuse
Feb 24, 2012 | Admiral AED4475TQ
My Whirlpool dryer Model # WED5300SQO and it just stopped. I had used it about 5 hours ago and it worked perfectly fine. I returned home later in the day and tried to dry another load of laundry and when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 19, 2011 | Whirlpool Dryers
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
My admiral dryer runs but has stopped drying the clothes to where I have to run the load five or six times and when I take out the clothes they are cool instead of warm. It does this with every drying...
either your heat cycling switch,hi-limit switch,thermistor or part of your element is defective or you don't have full 240 volts to operate your dryer i.e. only 1 leg of 120 volts it will run in some cases but will heat poorly
Oct 29, 2009 | Admiral AAV7000A
Hotpoint w440 washer/dryer keeps repeating cycle load?
Hi there, I've got a Hotpoint Aquarius washer / dryer and this has just started happening to me - it seems to get to the end of the cycle then repeat itself. However, I do not seem to be able to cancel the cycle, or am I able to switch it off. It's been going for about 4 hours now. Any ideas?
Feb 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Dec 30, 2007 | Dryers
Whirlpool LGV4634JQ Gas Dryer Logo
196 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
