Question about Insignia IS-PDO40922 Portable DVD Player
No Disk Whenever I try loading disks on to my player, it will say "no disk", and when it says that I opened it up and pushed in the button so that it starts loading, and it is not spinning as fast as it is suppose to.
No puedo acceder al menu se me perdio el control y quisiera ver si se le puede cambiar la region a cuatro gracias
Posted on Apr 15, 2008
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
DVD stuck in my Panasonic DMR-E30
Hi Rock.
I had the same problem like this on my machine. The best way to fix it is to turn the machine off completely and hold on the eject button then turn the power on. You want the first thing the player does is to eject the disk without trying to read it first.
I hope it works let me know if it doesn't and i'll try and recreate the problem on my player and see what i can do to get the disk out.
The last resort is to manually take the disk out but lets cross that bridge if my suggestion above doesn't work.
Thanks
smeags.
Feb 18, 2008 | Panasonic DMR-E30 DVD Recorder
Whenever the player is tried to open, automatically it gets switched off and I am not able to operate the same and hear songs
I think you might have formatted the Mp3 player using wrong format...
connect the player to the computer using an usb cable. It will open as a removable disk. Just make a right click on the removable disk and select "FORMAT"
Select the file system as FAT32 and format it using the default allocation size... Now load songs to your player, it should work....
May 19, 2011 | Transcend T.sonic 610 MP3 Player
Whenever I load a rental dvd, I get "Disk Error",
This unit has had problems playing dual layered dvds and since most newer are Dl try a older rental Movie and see if that works
Mar 28, 2011 | JVC DR-MV1S DVD Recorder/VCR
Logik lpd850 port' dvd returns to load disk after a minute or so
push down the button to open the lid, keep it pressed down. right next to it it a tiny button that detects whether the lid is shut. tape a little piece of folded paper onto it and then it thinks the lid is always shut. it just means you have to switch it off to remove the CD
Oct 09, 2009 | Televison & Video
Manaully open a disk player for a emachine
there's a small hole in the front of the disk drive close to the base of the tray and near the button used to open the drive. get a paper clip, open one end, hold carefully, and place it in the hole and push carefully till the drive opens.
to close, just push the tray back in firmly but without slaming it in. don't want to damage any of the gears inside.
Sep 24, 2009 | Computers & Internet
Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Apr 05, 2009 | Pioneer DVL-V888 DVD Player
Hyundia 7 inch dvd player model hd 719
I had the same problem. With me it was laser lens mechanism problem! the laser block justification needs to be adjusted. there is door button push it while a disk is there (the DVD will think the door is closed) then you will see what happens. Push the block softly till it recognizes the disk. If the disk is recognized it will play flawlessly till you change it or power off. The solution would be to readjust the laser block so you do not have to push it around every time you want to watch a film.
Oct 18, 2008 | Hyundai DV9806 Portable DVD Player with...
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Insignia IS-PDO40922 Portable DVD Player Logo
106 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
