it will shred but only after turning off and turning back on and putting paper in then I have to shut it off again. It is clean and no paper waste in the teeth.
-   I have the same problem. My Aurora AS1500CD is only 3 months old.
It was worrking fine and now I have to turn it off after every shredding.-   mufarooq
paper feed sensor is dirty, jammed or broken depending on what kind of sensor your unit has. I work with Fellowes machines but sounds like an issue I have dealt with on our machines. You should contact manufacturer for more detailed info on how to clean or unjam sensors.
I have a spl-qw120D shredder. Not used it much but as of a few months back it will no longer work. I...
(More)
I have a spl-qw120D shredder. Not used it much but as of a few months back it will no longer work. I put documents in the feeder, you hear the switch engage, but nothing happens. If I push the reverse button the blades will engage, but will not work on forward setting. I have taken it apart and tested the switches, they seem to be OK...assume circuit board is bad ? Where can I get one ?
Our Novitech shredder stopped working when we were in the process of shredding credit cards. We...
(More)
Our Novitech shredder stopped working when we were in the process of shredding credit cards. We shredded quite a number of credit cards, only 1 at a time as instructed on the shredder. We need direction. Thank you (mrteemac@bellsouth.net)
I have a Novitech PS-026/B2 shredder. It will run in reverse, but will not shred. I tried compressed...
(More)
I have a Novitech PS-026/B2 shredder. It will run in reverse, but will not shred. I tried compressed air to clean it out & Itried WD-40 on the shred teeth. Still no feeder shred.
