Question about Lexmark X1270 All-In-One InkJet Printer
Cable not connect but it is.
Hi, When I print it says that the cable is not connected but it is???
If you have Windows Vista, download the latest drivers for OS
Posted on Jan 19, 2008
I have dell 926 all in 1 printer,a dell inspiron1525 laptop i have uninstall/install the drivers from dell 3 times,print jobs Que but not print via laptop,not even a test page
Hi
Did you use the printer before that is connected to your laptop and prints fine or you are setting up the printer but unable to set up?
Before that check that all the cable connection are connected. Remove and connect it again, then when setting up the printer, check if it is reconized by your laptop by adding and setting up the printer once more.
Check also the printer's compatibility with the operating system? and install the correct driver?
Check also the USB cable and make sure you are using a USB cable port?
Please post comment for more help. Regards
Mar 31, 2011 | Dell 962 Photo All-In-One InkJet Printer
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Nov 05, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
The printer is not printing any document
Hi
Please check
1. Do you have a printer cable failure?
The printer will not be printing if its not connected to the computer. Check that the printer cable connecting your printer to the computer is firmly attached at both ends. Apart from this cable, there should be one more cable which is the one connecting to the wall outlet.
2. In case it still not work after checking try resetting and printing.
3. Else please change the Data Cable if it is very old one.
Jul 22, 2010 | HP LaserJet 1300 Printer
Does not print. Has red light
  1. Uninstall the drivers for your printer completely from add or remove programs.
  2. Unplug the cable from your computer connected to printer.
  3. Re-install the drivers using printer disc
  4. It will ask you to connect your printer while installing drivers so connect the cable.
  5. After drivers are installed try to print.
Good Luck!
Jul 20, 2010 | Samsung ML-2510 Laser Printer
Printer is not print properly
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq3
Aug 28, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
I have reconnected my HP PSC 1315 to my printer, however, I cannot get the printer to work. Can you please help me? The printer will not do anything. I have received a print test after I installed the...
Hi melovesjags:
Try these steps.
Does the product
print from the
computer?
Connect the parallel
cable or USB cable to the
product and the
computer. Use a wordprocessing
application to
send a print job to the
printer.
The cable is not
connected correctly.
Reconnect the cable.
An incorrect printer driver
is selected.
Select the correct printer driver.
Other devices are
connected to the parallel
or USB port.
Disconnect the other devices and try again
to print.
There is an LPT port
driver problem.
Reset the computer port settings. See your
computer user guide for instructions.
The formatter has failed. Replace the formatter.
Hope these help
Jul 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
When I select print all that happene is - sending data.
hi im josh in cebu phils. may i help you? friend try to check this: The first item to check is whether your printer is connected correctly to your computer. Check the connecting cable to make sure that the connections are tight. You also should unplug each end of the cable to ensure that none of the connecting wires are bent, making a bad connection. You might also want to change the printer cable. Cables can get old, and the wires inside can break; try a new cable and see whether this change fixes the problem.
good luck hope i helped you.
Mar 04, 2009 | Computers & Internet
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
