Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Draining problem The dishwasher during cycle drains well into sink but after machine runs completely, there is water still in bottom about 2 inches. No debris located.
  • 1,003 Answers
Repace timer or water outlet solenoid
Posted on Jan 18, 2008
My questions relate to GE Triton DW Model GSD 6660 G00SS My problems are multiple. I have run the diagnostics and all functions seem to be working but two conditions during operation remain a...
After you the drain to discharge the remain water and the tub is visibly dry of water,then you open and load it do you see standing water after you have drained and know it was gone??
If that is the case what i believe your trouble is that where the dishwasher drain connects to disposer under the sink the drain hose is only leading from that nozzle downward,if that is so what is happening is the dishwasher is draining ok but backfilling whenever water runs through the sink. To fix that use a string on plastic zip tie and attach a portio of the drain hose so at one point the drain hose under the sink is higher that the nozzle and water in the sink will longer run into the hose and run upward since water is only going to drain down and wont ever rise on its own.The drain pump is powerful enough to push the drain water up that "HIGHLOOP" very easily.
Good luck i hope this has helped you to fix your dishwasher,
Aug 08, 2011 | Dishwashers
Water leaked all over the floor after completing drying cycle
It is probably a clogged drain line that dumps into either your disposal if you have one or directly in the drain under your sink you may have an air gap on the sink they tend to plug around this area.
Apr 27, 2017 | Kenmore 15121 Built-in Dishwasher
Whirlpool DU915pwk80 not draining after cycle complete. I can run the cycle...and it doesn't overflow but it doesn't drain when its complete, i still have a couple inches of water in the bottom of the...
first thing that i would check is your drain line at disposer or sink.under sink. check to make sure its not clogged up. both the hose and were the hose hooks uo to look inside and see if blocked if so clean out with a flat blade srewdriver and test it, if drains better then that was the problem, also check for a kincked or pinched drain hose, if all that is good sounds like maybe your drain pump is bad. hope this helps
Sep 17, 2009 | Dishwashers
It doesn't drain completely
if ur unit is connected to an air gap,which is mounted rhs rear corner of ur kitchen sink,remove the air gap cover and look for any food debris stuck there.debris will restrict the free flow of water during and machine has fixed 2 min drain cycle. so some water can remain the unit after drain cycle is over.
Aug 17, 2009 | Maytag MDB3100 Dishwasher
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher with one inch of water in bottom when complete
undo the drain hose from your drain and put it in a 5 gallon bucket and see how it drains your sink drain maybe stopped up or if it drains into a disposal it may be stopped up
Apr 24, 2009 | GE Adora GHDA656LSS Stainless Steel...
There is a drain hose that runs from your dishwasher to underneath your sink. (usually connects in right below the drain spout)
It sounds like this may have become clogged, or the sink drain is clogged causing the water to back-up in to the dishwasher drain hose.
Mar 20, 2009 | GE GLD5800L Dishwasher
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Our dishwasher was gushing water after a cycle
If you dish washer pumped or drained water up into you sink then you drain line from the sink or even further down is clugged up, Machine out drain line. A drip sized cable machine can be rented. I recomend a 1/4 inch line. You will only have to go frim the sink to the main line.
Dec 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Water not fully draining during washing dishes. Stays approx 2 inches.
heres some few other simple checking & steps, that will guide you to the process...
Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink) and, using a wire, clean it. Also check the entire length of the drain hose for kinks and blockages, especially at the drain connection to the disposer or drain line.
Once the dishwasher is cool, shut off the power to it, and--if your dishwasher is made to allow this-- remove the strainer, located under the bottom spray arm at the base of the cabinet. Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
Determine whether the sink trap or house drain line is clogged
If it still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. At this point, it's usually best to call a repair person. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose.
Let me know..
Apr 19, 2008 | Dishwashers
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
131 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
