Question about Xerox Phaser 8500/DN Printer
Error Number 07,010.43:7106
I get an error number of 07,010.43:7106 and the machiine tells me to power down and contact xerox. Is this an item I can fix my self?
  • dreadnaught Jan 16, 2008
    Very fast response with ALL the right answers. The printer was apparantly turned off via circuit breaker each night and allowed to get cold. Room warmed up,cycled the printer several times and the system cleaned itself.
  • 2,072 Answers
That code has 4 primary reasons for occuring.
First off, the code is related to the print head not moving freely from a park position to a print position.
Causes mostly arise from the printer not sittilg level front to back and side to side.
In order are what mot frequently cause this code.
1. If you remove the covers, there is a stainless steel print head block on the lower left side of the machine looking from the front. It is just about mid machine and about 1 inch square. The ink can leak down into that block causing it to be extremennly sticky and not allow for free movement of the print head.
2.If you lost power or unpluged the machine with out cycling it down properly, the print head, wiper can be tacked to the print head, not allowing movement.
3. One of the cables attached to the back of the print head may be to tight not allowing the print head to move.
4. The process motor timing may be off, although this is listed as a cause, I have never witnessed it causing the problem.
The print head isself may be bad, I have seen that once, but that was kind of a freaky sitution and that would be in my opinion the least likely cause.
Posted on Jan 16, 2008
  • Rick Kasper Jan 16, 2008
    Good. Glad it's working. It is imoportant to cycle that machine down . Just the normal shut off will allow everything to move to the proper positiong.
    BUT do you know you are wasting a lot of ink shutting that down every night?
    Every time you cycle the machine from a cold start, the machine empties the print head of ink and refills.
    If you want to save a lot of ink, leave the printer on and allow it to go into its own sleep mode.
    Just a thought after reading that it's shut off nightly.
Can anyone tell me what code 19,003.48 means for Xerox 8560?
19,003.48: Scale and offset error is too large. The voltages measured have more than a 20% error from their expected values. Something is wrong with the Electronics Module or the Wave Amplifier.
To prevent these discharges, a Grounding Clip (P/N 650442700) was added between the Y-Axis Motor mount and the Pick Clutch. Check that this clip is installed and contacts the metallic portion of the Pick Clutch.
The Grounding Clip is factory installed in later versions of 8500/8550
models and in all 8560 models.
Oct 14, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
I have put new cartridge and giving LSU Error from Xerox PE220 work Centre
LSU stand for laser scanner unit, not related to the cartridge. Did you power down and back up and get same error? If so you'll need to replace the laser, part number 122N00243.
Sep 30, 2014 | Xerox Office Equipment & Supplies
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Error code 099-405
The error code refers to a Hardware "Pest" Fault (RAP Group:Power, Head Thermistors Name:Power, Head Thermistors). You should contact Xerox Support by phoning them directly. You'll find the numbers relevant for your Country here >>
Nov 30, 2013 | Xerox ColorQube 9303 Printer
Xerox phaser 8500 error 19003.48:33702
19.003:48 is the error code 33702 is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
May 21, 2012 | Xerox Phaser 8500/DN Printer
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit Item, Inc.
Nov 19, 2010 | Xerox DocuColor 3535 Copier
C2424: error code 19,993.48:88868
This error is a Printhead error, but in this case is usually more probable to be caused by the Electronics Module.
The Printhead part number is 650-4354-00
The Electronics Module is 119-6427-03
I suspect the actual error code was 19,003.48
Item, Inc.
Oct 03, 2010 | Xerox C2424 Copier
Error Code 10-399
Hello sir; The problem you have can be reset, just follow the steps as below;
1, power on the machine.
2, while hold down the 0 key, press start.
3, enter the access number 6789
4, click onNVM reset/NVM initialization.
5, enter 777-018 press start.
if still have problem let me know
Jan 02, 2009 | Xerox DocuColor 12 Color Copier
Xerox Phaser  8500/DN Printer Logo
2,244 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
