Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Start/reset button flashing
My dishwashers start/reset light is flashing and non of the other buttons will work, when i fully close the door it will start to pmp but there is nothing to put and dont want it to burn out. Is there a way to reset the machine or is it something more serious that will need to be serviced?
  • keystone12 Feb 27, 2008
    My ge profile dishwaser selectons buttons will not light, or beep.
    All the reast seem to work fine, is their a way I can fix this myself ?
The GE technician came to my place this morning and here what he told me.
The start / reset button is used to reset the current wash cycle. You just have to close the door and 90 sec later the dishwasher will be ready to start another cycle. This button is used usually to cancel a wash cycle.
A more drastic measure is to turn off the dishwasher breaker in the electric panel for 30 minutes in order to clear the memory of the panel. After 30 minutes, turn on the breaker and the dishwasher will be back to the factory defaults.
At this point you should not have any problems.
Michel
Posted on Jan 28, 2008
    Genius:
  • 1,003 Answers
I THINK ITS A FAUTY DOOR SWITCH
Posted on Jan 18, 2008
6ya staff
SOURCE:
How do I reset a flashing green start button
Blinking start button usually means a bad door switch cannot reset the control does not see the door as closed
Aug 14, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher won't start
May 16, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
Bllinking "clean" and cant start a new load? Need to reset? How to reset?
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 08, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
-high temp wash
-heated dry
-high temp wash
-heated dry
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
I have a Kenmore Elite Ultra Dishwasher and the cleaning light is flashing. I have tried pressing the start/resume button and closing the door within 3 seconds. I am not able to turn on my dishwasher. I...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 02, 2009 | Dishwashers
The clean button keeps blinking, will not go off and i cant restart to wash. i hit the heat dry button for six seconds and it was unlocked but i cant get the washer to restart.
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking clean light
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Clean light flashing - no other buttons available
-high temp wash
-heated dry
-high temp wash
-heated dry
Nov 05, 2008 | Kenmore 24 in. 16182 / 16189 Built-in...
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
1,486 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
