Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral side by side Freezer door problem
We have a side by side that the freezer door has a resistance and tends to open when we close the refrigerator ( side ) door.
    Master:
  • 619 Answers
Hi , let the freezer incline put pieces of thick cartoon on front legs of the freezer so that the door will shut , the door contact magnet are weak. check also the screw and bolts of the door might lose.
Posted on Jan 22, 2008
I have an admiral fridge freezer model number GS2126CEDW.water keeps leaking from the front of the freezer and a build up of frozen water has accumalated at the bottom of the freezer.A person has advised...
hello again,
Sorry to hear that the drain is clear and not the problem, some of the other things that cause that water are;
Freezer door gasket...is it curled up in the corners espicially on the hinged side so air is leaking in and condensating resulting in water
The tube that send water into the icemaker is partially frozen so when water enters the icemaker it's being sprayed and dripping to the bottom(if thats the case ice would probably be built up all over the freezer)
The door for the ice dispenser isn't fully closing and will cause condesation just like the door gasket would
Good luck,
GENE
Oct 12, 2011 | Admiral 26 cu. ft. Side-By-Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Refrig side not cooling, freezer fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
I have an admiral GC2224GEKB
You may have to open the door to let the dispenser thaw since it's in the door.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 03, 2009 | Refrigerators
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer door opens When you close refir. door
The freezer door is relatively light weight, and when the fresh foods door closes, the air has to go somewhere and the easiest escape route is to momentarily pop the freezer door open. The door should close again quickly. If is does not, make sure the freezer door liner is not touching the top or bottom, causing dragging resistance, and make sure that the front leveling legs are raised up so the door closes by it's self when released from a 45 degree opening. Sometimes the hinge side gasket rubs and holds things up also, especially if that area was cleaned. If that is the case, rub a film of wax on the hinge side gasket to lubricate it. Additional weight in the freezer door will also help.
Oct 27, 2008 | GE Profile Arctica Stainless Steel Top...
My fridge freezer has stop working but if you open the door it start to work but if you shut door it stop's and you can hear the fan in freezer stop and start it's a admiral gc2224gekb side by side
Hi thanks for te question. it should be the opposite of what its doing did somebody work on this fridge before. it looks like somebody switched the light and the fan switch
Oct 07, 2008 | Admiral Refrigerators
Will not dispense water or ice
Check for broken or frayed wires at the bottom of the freezer door.
There is a wire harness that is routed around the bottom of the freezer door right by the hinge.
After many opening/closings of the freezer door, these wires tend to break or fray and short or open.
Aug 22, 2008 | KitchenAid KSCS25FKSS Side by Side...
Admiral 23ADiW side by side fridge freezer
Is the back of the freezer section iced up?
If so you could have a defrost problem. All the cooling components are in the freezer section there is a damper controlled by a dial in the refrigerator that opens and closes.
If the damper is closed it will not allow air into refrigerator section. It is seperate from the Thermostat.
If the damer is opened to much you can start freezing food in the refrigerator section.
If there is ice on the back wall of the freezer section. It is not defrosting. There are 3 parts in the defrost process. The thermination stat, the heater, and the defrost timer or it's a timer on the electronic board behind the metal plate on the back of the refrigerator.
Good Luck
May 20, 2008 | Admiral 26 cu. ft. Side-By-Side...
Side by side
Suction at door is caused by the rapid reduction in air volume after you have had a freezer door open and then close it. The refrigerator door side does not have as pronounced air reduction volume due to less temperature difference.
Test you door gasket seal by closing the door on paper (dollar bill) works fine. If you have resistance when sliding or pulling on the paper you have a good seal. No resistance means your door is not sealing properly.
Apr 29, 2008 | Frigidaire FRS23H7C Side by Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
99 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
