Question about Marantz PMD660 Digital Voice Recorder
Headphone socket detached from casing.
The headphone socket has become detached from the casing and is therefore unable to be used because it is inside the unit. In an attempt to open the case, I unscrewed the the fixing screws under the casing and beneath the batteries. However this did not enable the casing to be opened so that the headphone socket could be reattached to the casing.
I didn't wish to make matters worse by being too heavy handed at this point.
Is there such a thing as a technical manual which explains how to get at the internal workings of the unit? Or can anyone describe the procedure from previous experience?
Thanks allot in advance :-)
  • Anonymous Feb 05, 2008
    Exactly the same thing - headphone socket fell back into the recorder, can't figure out how to open the front. And I do this stuff for a living. With these plastic things you don't want to push too hard because they are so cheaply made.
I posted step-by-step instructions here for fixing PMD660 headphone issues. Check it out.
Posted on May 31, 2008
OK, took back off, thank you for your advice, it was the battery box screw that was holding the back on. Then removed two cables, (one ribbon, one brounding) the volume control pot and cable assembly, but now there is still something holding the front of the machine (at the top) in place. I can't see in there, tried pinching it, but don't want to break the plastic. You have to get the front off to resolder the headphone stereo mini jack back onto the card.
What's next? What am I missing?
Thanking you in advance
Posted on May 08, 2008
I have 2 of thexe pmd660's - both are down with the same problem. I work at an NPR station, this is becoming embarassing. Is this a design flaw or what?
Posted on Apr 28, 2008
I was having the same problem, but finally got it to crack open gracefully. There are quite a few screws, maybe about 7 of them. Once you get all of them out (including that one beneath the battery), pry open from XLR side. It should go up a good few degrees. From there, it should just come apart.
The headphone jack is a few layers in and you'll have to undo cables and one ***** towards the front, but on the inside. It holds the push tab to eject card.
Posted on Mar 10, 2008
Unable to hear system through speakers,but ok through headphones
Make certain the connections to your speakers are good. Test each of your speakers with a 1.5 battery. Put the + and - ends of the battery to the + & - of the speaker (not connected to amp). Just for a short time only - the speaker should "pop".
If they are good you might have damaged the headphone socket on the machine. These disconnect the speakers when the headphone jack is inserted. Sometimes the contacts break or become bent out of place thus not reconnecting the speakers. This can be easily fixed and is not an expensive repair. The only exception would be if there is a switch to switch off the speakers on the unit itself. But if in the past you have put a headphone jack in the unit when the speakers were operating and they cut off then a faulty jack socket is to blame.
Feb 06, 2015 | Audio Players & Recorders
No audio in speakers only in headphones
If inserting headphones before the fault caused the speakers to switch off. Then you should look to the headphone socket as the cause of the problem. It could be that inside the contacts have become bent out of shape. You might need to replace the headphone socket. If you can use a soldering iron you can do this yourself. Otherwise it's not an expensive repair.
Apr 24, 2013 | Panasonic SC-AK24 CD Shelf System
I have some Labtec speakers which work perfectly with my PC. I got a Macbook for Xmas and converted everything over including itunes and am now unable to use the speakers. Is there a cable other than the...
According to the specs your speakers are intended to use a standard 3.5 mm stereo headphone jack. I doubt your new Macbook will not be equipped with such a jack socket and so if they don't work when plugged into the headphone jack of the Macbook but do work in the headphone jack of the PC it is clearly the fault of the Macbook - maybe the socket is faulty or hasn't been enabled or something.
Sorry but I know nothing about Macintosh other than I hear they are almost entirely interchangeable with Windows these days. If they don't have a headphone socket it would seem they are actually inferior rather than the superiority they claim.
Nov 13, 2017 | Labtec Spin 70 Computer Speakers
( no sound from speaker) i detached the grundig headphnes from my satellit 800 millenium -- the speaker remained 'silent' --otherwise, the radio appears to be functioning normally -- the radio functions...
it maybe that the cut off switch in the headphone jack has stuck as you place in a jack to the headphone socket there is a small switch that mutes the normal speakers and this should switch back on as you remove the headphones, this may have stuck. you will have to open the back and check the back from inside. try to short the mute and see if that is the problem. maybe squirt a small amount of contact cleanrer spray in the jack hole and insert and remove the headphone jack a few times this may resolve.
I hope this was helpful
Dec 12, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Head phone socket intermitent and now failed. Any idea what to solder where?
the headphone jack would either be a 3 prong or a 4 prong. meaning it was either had 2 contacts on the headphone barrel or 3 contacts and the last prong being for ground. If you desolder the headphone jack you can easily determine this. Then you can goto a radio shack and pick one up for under 5 dollars. Problems that may come into play are is if they used a low profile jack over a standardized. But even if its 3.5mm or 2.5mm radio shack generally always sells them. You could also purchase them online. Most likely the cause is the contacts inside the headphone jack are no longer making contact with the barrel of the headphone plug. But if its not the headphone jack then it is possible the amp inside the unit has broken. also if you open the unit up determine if the solder on the headphone jack that makes the contact may have become cracked. If that is the case just heat up a soldering iron and make circles around the solder, but be careful not to spread the solder and cross connections.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Samsung YP-K3 MP3 Player
Beyer dynamic dt 100 headphone 400ohms. There's
It could be that the Earth connection has become detached in the cable or plug somewhere!
Oct 13, 2009 | Beyerdynamic DT 100 Professional...
Hi i use my laptop for disco, and use the headphone socket
hi is the socket on the actual machine broken? if that is the case you have courses of action the socket or you can buy a usb headphone adapter and plug your headphones in using the adapter.
May 07, 2009 | HP Compaq Evo Notebook N620c
Can i use headphones on the nc10 ?? if so, which socket ??
It appears that on the right hand side of the notebook you should see a green socket. It most likely has a picture of headphones or so. This is how you may use your headphones.
Let me know if you need any more help with this.
Apr 19, 2009 | Samsung NC10-14GW PC Notebook
My psp speakers dont work the head phone jack came loose and only plays out of one head phone and the up joystick doest go up all the way in a game so i walk slow, can i fix these problems and how ???
You have either what is called a dry joint on the headphone socket or the headphone socket is broken.
When you plug the headphones in it switches off the speakers, so if the socket gets damaged or becomes disconnected from the board the speakers will also not work.
you need someone with VERY good soldering skills and a spare headphone socket to repair or replace the socket
Couldnt say whats happening with the joystick, maybe a bit of the headphone socket has got jammed in it, you probably wont find out untill the psp is opened up
May 25, 2008 | RIM BlackBerry Pearl 8100
Marantz PMD660 Digital Voice Recorder Logo
141 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
