Question about Sage Instant Financial Suite v8.0 CD Win (13904) for PC
Sage line 50 nominal reports.
Will not report and error message states:- "unable to connect to data source. check configutation"
  • 28 Answers
Reinstall ODBC Drivers usually found in your sage data directory
Posted on Nov 11, 2008
Hi all I am gettig the following with my sage line 50 v7 'sage report says unable to connect to data sourc, check configuration' I then get a system error coded 2 Its on windows 98 Can anyone...
Try removing Microsoft.net framework 3.5 sp1 from add remove programmes has known conflict with sage. If this does not work then try removing the .net framwork 3.0
Oct 05, 2010 | Sage Instant Financial Suite v8.0 CD Win...
I want to transfer all sate data from my old laptop to my new PC, I have already installed the hardware on the new PC
Sage has an EXPORT function that you can use to transfer data.
You could also copy the daily files from the storage folder to a USB drive
O the new machine use the IMPORT function to import a backup of the files or use the folder options to get data from the USB drive to set up a new company profile which would use your old data to set up a new copy of SAGE with your exisying information.
The prefered option is IMPORT / EXPORT
Feb 21, 2010 | Sage Instant Accounts 8.0 (013604ug)
When I try to print reports in the Financial window on Sage Line 50 I get an error message C Prog Files x86|AccRep\*TB.SRT contain invalid path. how do I fix?
find the TB.srt file and copy it into location should solve this. You may also have a problem with profit and loss and balance sheet as these are normally held in same location
Feb 09, 2010 | Sage Instant Accounts 8.0 (013604ug)
C:\program\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid pat
This message usually comes when the target location is not there or is renamed OR the address is wrong. Open My Computer, and go to the address you gave. Look if there is the file named *TB.SRT.
And by the way... the address you gave was "
C:\PROGRAM\\SAGE\ACCOUNTS\REPORTS\\*TB.SRT" BUT I believe that the address should be "C:\PROGRAM\SAGE\ACCOUNTS\REPORTS\*TB.SRT".
It is not possible that the address contains 2 slash (\\) repeatedly. Open the file by going to the My Computer OR by opening the software and by locating the file manually from there.
live chat assistance costs $19.99. And $12.99 for one time e-mail premium support.
If you have a registered product then I would suggest you to visit:
http://support.sage.co.uk/default.aspx?page=1
There you might find a solution at no cost.
Please inform if your problem is solved or not. And please rate if you found the above info useful.
Aug 28, 2009 | Sage Instant Accounts 8.0 (013604ug)
Email Remittances - Report Designer Problem
Sage Line 50 Addpurch Utility
In Sage Line 50 V5, you could only produce remittances for the
supplier accounts you had set up in your Sage Line 50 program.
The information that appeared on your remittances was taken
from the supplier ledger.
In newer versions of Sage Line 50 you can produce remittances for suppliers
who do not have a corresponding supplier record. This allows
you to produce free-format cheques for one-off payments. To
enable you to produce free-format cheques, Sage Line 50 no
longer takes the information for remittances from the supplier
ledger. This means that you can produce remittances whether
there is a corresponding supplier record or not.
If you want to include additional information from your
supplier records on your remittances, for example bank sort
codes and account numbers, you should convert the layouts
you require using this utility.
Note: This utility is installed automatically into your
Sage Line 50 program directory when you install Sage
Line 50.
>> To use the Addpurch utility
1. Open a Command Prompt by clicking on to your Windows Start Button
selecting Run, then type the word COMMAND and click on to OK.
From the command prompt (for example, c:\windows\desktop>) type cd\ and
then press ENTER.
2. At the c:\> prompt type cd "Program Files\Sage Accounts\layouts"
and then press ENTER.
The prompt should now read c:\Program Files\Sage\Accounts\layouts
Note: If your Sage Line 50 program is installed in a different
directory replace the above instruction with your own directory
name. The directory path can be found within your program by
clicking on to Help and then About and choosing the System
Information Tab. Your layouts will be held on the same path
as your data directory.
3. Before you can convert your remittance layout you will
need to save this with a new filename. (maximum of 8 characters).
For example, to rename one of your existing layouts from
the c:\Program Files\Sage\Accounts\layouts prompt type:
copy remita4.sly newrema4.sly
Jul 07, 2009 | Sage Computers & Internet
I cannot save my reports to file to send in an email
Could you save your reports previously to send seperately? If so what format did you save your reports in? Are you receiveing any error message when you try to save your reports? If so what is it?
A quick work around is if you install a free pdf programme - Cutepdf comes to mind, you can then set to print your reports in cutepdf, save as a pdf file and email them... If you need to do this, I can talk you through it in more detail.
May 14, 2009 | Sage Instant Accounts 8.0 (013604ug)
Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Apr 14, 2009 | Sage Instant Accounts 8.0 (013604ug)
Error message -no loop current
It can't find a DIAL TONE check the line with a regular phone.
Mar 06, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Error message with sage instant accounts
If you are unable to logon to Sage you can try deleting the Queue.dta file. All users MUST be logged out of Sage and Sage should not be running. Sage will recreate the queue.dta file when it is restarted. The Queue.dta file can be found in the ACCDATA folder for the Sage Company Data that is experiencing the problem.
Note that the "Username already in use" message from Sage can occur if Sage wasn't shut down tidily for that users session. If you are sure that the user is not actually logged in it's OK to allow Sage to clear the session and log in.
Jan 13, 2009 | Sage Instant Accounts 8.0 (013604ug)
Sage Instant Financial Suite v8.0 CD Win (13904) for PC Logo
1,288 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Clinton Daley
Clinton Daley
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
