Posted on Dec 02, 2009
Casio ce 3700 is stuck on error E-04 . how can i clear the error
  • albert1965 Dec 28, 2009
    can any one tell me how to clear E04 on a casio 3700 ce?
5 Related Answers
Anonymous
  • 1257 Answers
  • Posted on May 03, 2008
SOURCE: casio ce-3700
E-04 Key in mode switch was turned before completing last opereration. Turning key to X then pressing subtotal usually fixes problem.
For more innformation use link below
http://www.olskey.com/support.html
http://www.olskey.com/casioshooting.html
Was this solution helpful? Show your Appreciation by rating it:
Thanks
Dilip Bagdi
Technical Associate
Anonymous
  • 737 Answers
  • Posted on Mar 04, 2009
SOURCE: casio error 04 to 09
Hi. It means the password has not been entered. I suspect this machine has not been RAM cleared properly after the battery was changed. What MAC code did you enter when you changed the battery and initialised it?
Mark
Anonymous
  • 737 Answers
  • Posted on Jan 19, 2010
SOURCE: casio tk-1200 stuck on error E-04
Firstly, try a flag clear. This will not lose any of your data:
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL.
Turn key back to REG mode and try it
Electroboy
Electroboy
  • 1888 Answers
  • Posted on Jan 22, 2011
SOURCE: casio ce-3700 error 04 on
The machine is trying to complete an initialisation. It has probably not had its battery changed on time, or it may have been left off for too long. You need to check the internal rechargeable battery and replace if necessary. You can re-program it once the battery has been checked/ replaced.
C-tech has a CE-3700 manual here if you want to re-program it yourself: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
If you need information on servicing it, the service (repair) manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_and_CE-3750_service_manual.html
General Systems Consulting
  • 5051 Answers
  • Posted on Apr 10, 2012
SOURCE: how do I clear error code eo4 on my casio ce 3700
What were you doing or trying to do when you got this error code?
1helpful
MY CASIO CE-3700 CASH REGISTER SAYS E33 WHEN IT IS TURNED ON. How do I correct
Hi Josie. E33 means you have not entered amount tendered.
turn key to REG
Press SUBTOTAL
An amount should show on the display. Note this amount.
Type the amount shown on the display with no decimal e.g if display shows 12.30, type 1230.
Press CASH
Drawer should open.
If you cannot clear the error (try the clear button C) or no amount shows when you press SUBTOTAL, it probably means the memory has become corrupted due to a flat or faulty battery.
If anyone needs more information, C-tech collective have the Casio CE-3700 manuals here:
http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
How do I clear error code eo4 on my casio ce 3700
Casio ce-3700 showing some percentages on it's reading.how take that out?
Which percentages? Which reading? You will need to be more specific. If it is part of the daily report, the user manual should be able to show you what they mean. If you need more information, the Casio CE-3700 manuals are here:
CE-3700 Operation/ programming manual:
CE-3700 Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_and_CE-3750_service_manual.html
Have a ce-3700 raized keyboard the till resets and can set date and time but the departments won't work one needs to open the department so that ne can work the till how
If you have performed a RAM (MAC) clear, then the departments should work as soon as the MAC code has been set. Make sure you aren't using a decimal point for prices. -----------------------------------------------------------
The Casio CE-3700 User and Programming manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
The Casio CE-3700 Service (repair) manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_and_CE-3750_service_manual.html
Casio ce-3700 error 04 on till please help
2helpful
My casie ce-3700 is showing error code 08, how can i resolve this problem?
You have logged yourself off. Try pressing 1 then CLK#
If anyone needs a Casio CE-3700 manual, C-tech has them here: http://the-checkout-tech.com/manuals/cashregisters/casio1.php
I have a casio CE-3700, I do not have the instruction manual. I do keep getting error code 01 after I did the clear out
Hi. It probably needs resetting. It's hard to get manuals now and Casio don't let me distribute them. the-checkout-tech.com has one available and it's cheap:
Preview of manual:
http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/CE-3700_operators_and_programming.TOC.pdf
Full manual:
http://the-checkout-tech.com/estore/catalog/advanced_search_result.php?keywords=CE-3700_operators_and_programm&x=0&y=0
If you get a manual, I can guide you through any parts of it that you don't understand.
1helpful
Casio error 04 to 09
Mark
13helpful
6answers
Casio CE-3700 cash register MAC instructions
Hi. I would advise both of you to try a flag clear first to see if you have any program left.
Turn key to program. Power off at wall.
Hold RECEIPT FEED, and turn power on at wall.
Wait 10 seconds, then let go of RECEIPT FEED.
When you see 'FFFFFFFFF' press SUBTOTAL.
Turn key back to REG and try it.
If you still need help, let me know.
Mark
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
