Question about Sony VAIO VGC-V617G PC Desktop
Black Screen Hi, I have a Sony Vaio VGC-V617G and my computer won't seem to get out of the black-screen mode. I turned off and then turned on the computer and everything seems to be functioning ( I can hear it running), but it never exits the black screen mode. What is unusual is that when it is starting up the normal sign VAIO flashes (white) on the screen and then returns back to the black screen. Please help!
  • 2 more comments
  • star1et Jan 16, 2008
    My computer is built into my monitor LCD
  • MaxMuhlin May 12, 2008
    Yes, I have the same problem with my Sony VAIO VGC-VA10G desktop. These computers DO NOT accept an external monitor. See picture at the top of this page. . .the Monitor IS all there is except for a very small box containing the operating system located just below the monitor.
    My computer is definitely running inside there. . .but without being able to access it via the Monitor, I may as well be trying to access the computer next door.
    MaxMuhlin
  • conrobiso647 Oct 09, 2008
    I have the same black screen problem with my Sony VGC V617G. However, I have log me in installed on it so I can access it from another computer and all is fine. The F2 tricked worked once but now it will not. Any other suggestions?
  • Anonymous Apr 29, 2009
    I HAVE A SONY VGN CR42S/L BLACK SCREEN NO LOG ON SCREEN. I HAVE BACK UP DISCS THAT DONT LOAD.VAIO RECOVERY CENTER WONT RESPOND. CAN GET OPTIONS FOR SAFE MODE, NETWORKING, START WINDOWS NORMALLY.
    START WINDOWS NORMALLY & SAFE MODE JUST GO TO BLACK SCREEN.
    CAN YOU HELP MY THANK YOU
    Genius:
  • 1,003 Answers
DISPLAY HAS POBABLY WENT BAD.
BUT THE WAY TO MAKE SURE IS TO CONNECT YOUR COMPUTER TO A DIFFERENT MONITOR TO SEE IF YOU GET THE SAME RESULT
Posted on Jan 16, 2008
Whoa. I'm not sure why, but this just worked. As soon as I hit F2 repeatedly, the machine restarted without a problem. Woooohooooo!
Posted on Sep 28, 2008
Actually, I called sony and I'm so glad they helped me out. Here's the procedure.
1. When the computer restarts, press f2 repeatedly.
2. On the bios setup, select exit
3. On exit screen, select Load default values
4. Hit enter
5. Save and Exit.
Posted on Aug 28, 2008
  • Brian McGrath
    Brian McGrath Jan 20, 2014
    I tried the above and I either get a three step scan of my hard drive and then a black screen or I get a resuming windows message but it just goes back to black screen. Any help would be greatly appreciated.
How do you remove a hard drive on a Sony Vaio VGC-V617G? Thank you
The hard drive is located in the rear of the base. Remove the black plastic cover. Just look for the black screws holding it in then pull it back and up. The hard drive is held in place by four screws on the back side. Some components in this PC are for laptops however the hard drive is a standard PC size and connections.
May 25, 2011 | Sony VAIO VGC-V617G PC Desktop
The screen starts up black, how do i fix it?
check ram and proccessor then check power supply
Jan 15, 2011 | Sony VAIO VGC-V617G PC Desktop
My logo comes up then the intel logo and a small white line then the screen goes black and nothing else will load. Is there something I can try?
Try loading in "SafeMode" when you cut on computer, tap F8, a screen will pop up with a bunch of ways to start the computer, arrow to "Safe Mode" and press enter, If it boots now you probably have a virus. If you have a antivirus program run it.
Feb 22, 2010 | Sony VAIO VGC-V617G PC Desktop
What can I do my sony vaio vgc-v617g pc I STARE and after 40 minutes my screen is dark
Is it only when your PC is Idle for 40 minutes?
Check your power saving options.
Jan 31, 2010 | Sony VAIO VGC-V617G PC Desktop
Computer keeps returning to "safe mode" options screen
If you choose Start Normal and it boots into safe mode again then you should get professional help if you value any of the files on your computer and don't want to loose any data.
Jun 01, 2009 | Sony VAIO VGC-V617G PC Desktop
My sony vaio wont turn on
you can check your smps which is the necessary component to supply the power to the motherboard. u can check the smps is working or not by shoting the black and green wires by a jumclib.
Feb 22, 2009 | Sony VAIO VGC-V617G PC Desktop
My sony vaio makes a beeping sound one long and to short beeps and it wont turn on
One long beep and two short beeps usually means a video problem. If you have an add-on video card, try replacing it with a new one. If you are using an on-board video, go into the bios and turn it off. then shut down & install an add-on card.
Black Screen
Look in the back of the Gateway where you currently have the video cable connected. If there are two connectors, (Side by Side) there than disconnect & re-connect to the other. Your display should come up. Don't be fooled. Most Pc's that have no display on their monitor is not a monitor problem but a computer problem.
Feb 08, 2008 | Sony VAIO VGC-V617G PC Desktop
Sony VAIO VGC-V617G PC Desktop Logo
2,461 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
