Question about Gemini XL-500 Turntable
Left output from one of my turntables cuts out regularly leaving a hum
I have a pair of stanton STR8-30 's which i am using with a NUMARK DM1002 MKII mixer. The output from one of my turntables regularly cuts out on the left side leaving a constant hum. The only way i seem to be able fix it is to turn my mixer on and off a couple of times or fiddle with the wire for ages, but this doesn't always work (or not for long anyhow). Ive tried changing my cables and mixer but this does not work. Could it be a problem with my grounding? My mixer only has one ground connector for both decks. Or do you think my turntable is broken?
  • 515 Answers
No, the issue is either with the RCA cables or the tonearm. You might also want to check your cartridge and headshell connection. Make sure the contacts are nice and clean, and securely on the headshell. Have you tried swapping out your turntables? Take the left turntable, and put it on the right channel's input, and vice-versa? This will tell help isolate the issue. If the problem just moves, then we know it's not your mixer. If the problem remains on the same side, then you know there is something wrong with your mixer.
If the problem moves, then you can safely say it's your turntable with the issue. The STR8-30's aren't the greatest quality, so it's also possible that you have a faulty tonearm or RCA cables.
Hope this helps.
DJPROAUDIO
TWEAK AV LAB
Posted on Jan 19, 2008
Stanton STR8 150 turntable right output not working
Check the connections at the rear of the cartridge. Something may have worked loose while in storage
Oct 02, 2012 | Stanton STR8-150 Turntable
Stanton STR8-100 Turntable ground wire?
There is no such ground points in the Stanton STR8-100. The main thing you have to check is the RCA cable used. You should a high quality RCA cable suitable for Phono connections. If you use a normal RCA cable then it will produce HUM because if its weak ground shield.
Try with a good quality RCA cable with Good ground shielding.
Ajin
Apr 27, 2012 | Stanton STR8-100 Turntable
Both Technics SL1210 mkII's loud hum and almost no sound...
You seem to have some feedback hum from somewhere. I would think it might be caused by a faulty connection somewhere.
Mar 12, 2017 | Technics Audio Players & Recorders
How do i hook a numark tt 1625 turntable to a regular home stereo amplifier...does the ground need to go into anything specific?
Turntables require a special input in the amp (usually marked PHONO) because they require high gain and different equalization - and yes, that ground wire has to go to ground unless you want to get a super annoying 60Hz hum from it!
If your amp doesn't have a phono input, you're going to have to go out and get a phono pre-amp and connect it between the turntable and the amp.
Best of luck!
Feb 26, 2011 | Numark TT1650 Turntable
Have a stanton STR8 60 turntable that I forgot about. Hooking up it only has one output. Where do you put it?
turntables have very low output signal need a phono input to amplify it more than cd,cass. if has mono output use rca conn 2 to 1
Jun 10, 2010 | Stanton STR8-60 Turntable
Where do I connect the ground wire from my amp to Numark TT USB?
i used to have stanton t80s,had the same problem no gnd on deck but diddnt need it there waqs no bad earth so if it sounds good leave it
Jul 18, 2009 | Numark ttUSB Turntable
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
Wiring cartridge
The "Standard wiring" is: Red = Right Hot= R Green= Right Ground= RG White= Lefty Hot= L Blue= Left Ground = LG Black if used is "Ground" and should be connected to a seperate ground circuit. Seems to me you are missing a couple of solder points. Also try twisting the pairs together but not all 4 together; i.e.(red & grn) (White & blue) to reduce "hum". Hope this helps.
Jun 02, 2007 | Stanton STR8-100 Turntable
Gemini XL-500 Turntable Logo
252 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
richie46
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
