Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
No sound from TV only when playing DVD
I have a Samsung TV plus the surround theatre system to go with it. I bought the lead which enabled me to watch DVD's with sound from both the TV and the surround sound, but this has recently stopped working now when I play a DVD I am only getting the sound out of the surround sound not the tv. The TV works fine sound coming from the TV and the surround sound!! Has something been pressed on the remote control?
Many thanks
Tracy Hampton
  • peta1p Apr 12, 2009
    Hi - Too bad the question was not answered wellas I have just come into the SAME exact problem.......any solutions would greatly be appreciated.
    Sniper:
  • 59 Answers
When the tv is hooked up to the suround system u dont want sound to come from the tv cause you will hear a echo it best to let the sound come from ur home theater
Posted on Jan 09, 2009
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
Posted on Jan 16, 2008
6ya staff
SOURCE:
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
Surround sound for DVDs.
If your DVD disc supports it, you will have to enable surround sound from the DVD, as well as the speakers.
May 10, 2008 | Koss KS3102 System
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
I have a 5.1 jvc dvd surround system and have just bought a 37'' new lg tv. The system plays in stereo when listening to just tv. It does not have an HDMI connection on the DVD. Can i update with a blue...
Your LG tv should have an optical output socket,if your surround system has one as well,(input) then connect an optical lead from the tv to the system,then select either input 1 or opti 1(depending on your system) you will then get the sound from whatever you are watching on the tv
Nov 04, 2009 | Televison & Video
Surround sound hok up
try using a HD plug in cable that should solve ur problem
Mar 01, 2009 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
Dec 26, 2008 | Samsung 1000W 5.1-Ch. Home Theater System...
Surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
Nov 25, 2008 | Audio Players & Recorders
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
430 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
