Flat Panel Televisions Logo
Problem with LG Flat Panel Televisions
I want to connect my HiFi to my LG LH 3000 TV.. I have tried two plugs in the Audio L & R but no sound through HiFi. Have tried switching TV speakers off, still no sound.. My previous TV was
Panasonic.and old Amstrad.. both worked fine with two plugs in Audio sockets. . same set up but different TV..wont work...what do I need to do? thanks
Posted by avatar on Dec 02, 2009
Suggested Solution (3)
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
  • by Author image john_duggett Over a year ago
Source: Hitachi L26H01U headphone socket doesnt work
Was this solution helpful?
No
Yes
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
  • by Author image rgodley Over a year ago
Source: LG 42PX4DV - HDMI Audio / PC Audio IN problem
No
Yes
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
  • by Author image normendez Over a year ago
    • By avatarnormendez Oct 07, 2008
    • I found one on ebay but if you don't have a ebay and a paypal account you will have to set one up or scour the internet for one here is the link
      http://cgi.ebay.com/Sony-Playstation-2-PS3-A%2FV-Cable-PS1-PS2-PSONE-AV-*NEW*_W0QQitemZ250303808466QQcmdZViewItemQQimsxZ20081004?IMSfp=TL081004103006r24906
      Personally I would use amazon.com because you don't have to set up a entire separate account just to pay for your item and I don't trust paypal here is the link if it does not work just go to amazon and type playstation 2 in the search bar then sroll through the items till you find it. Cheers!
      http://www.amazon.com/gp/offer-listing/B000GACEHQ/ref=sr_1_olp_12?ie=UTF8&s=videogames&qid=1223356916&sr=1-12
Source: Connecting Sony PS2 to Panasonic HT32LZD85
No
Yes
Tips for Helping ianroberts62 With Their Issue
  • Give detailed step-by-step instructions
  • A picture or video is helpful
  • Use plain language not industry jargon
  • Check spelling & punctuation
Hide Tips
Add Your Solution
