Question about Microsoft Xbox 360 Console
Xbox 360 dvd problem
I try insert game to dvd drive when they loading flash the disck the drive it open automaticaly.
im just wondering why happen this?
  • louie07 Jan 16, 2008
    pls. help may for my question to all knowing this. thanks!
    President:
  • 4,402 Answers
Bad dvd drive
try this
I just solved this problem, very simple actually. Possibly can happen when the drive WILL close, but then loud noise as it tries to spin the disc up. Open the drive up (4 little screws on the bottom) and lift the lid up. If you look on the top white magnet spinner, the bottom side of the magnet system broke off of the disc motor. It will look like a little metal ring stuck to the white spinner thing whatever it's called. I popped that off and examined it, then used some krazy glue to stick it back on the motor spindle and it's away and going now. The reason the drive will not close, is because when the little magnet first breaks off it can get misaligned then when it tries to shut it gets in the way. The MAY be the cause to the problem. I fixed this issue today with mine, hitachi drive.
The laser going bad is a pretty common issue with the drives, since it's a Hitachi that spindle motor could be all gunked up with dirt as well and cause that issue also.
if ya have a Hitachi, if it's a Samsung it could just be the laser.
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Posted on Jan 18, 2008
Wait do you have to open the consol3?
Posted on May 01, 2008
On my xbox 360 when i'm playing a game then suddenly directs me to the desk top and when i shut my xbox 360 off the power button flashes green every few seconds why is this happening ?
It sounds like a DVD drive error. When the center light inside the "ring of light" blinks rapidly it thinks the DVD drive is either open or not connected. You can buy a new DVD drive off Ebay for a decent price or take it to a professional shop. When changing the DVD drive you have to also put the original PCB from the old drive onto the new one or it will not play games. It will play DVD's all day but no games. There is a bit of soldering involved. If your not confident you can make the repair check out this site for help. www.jbgaming.com they do good work and are very reasonable.
I’m happy to help further over the phone at https://www.6ya.com/expert/jay_25de800b00457e27
Mar 17, 2013 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
My x box will play cd's and dvd's but not games. do you know what i can do to fix that. when i put in a game it says to put disc in an x box 360 console.
Here's how:
1. Carefully open the Xbox by removing the torx screws and then releasing the clips that hold the case together. The clips and molding pieces all come off easily; pry them open carefully.
2. Load the flash firmware disc into the DVD drive and power off the Xbox.
3. Disconnect the DVD drive from the SATA cable and note the brand of drive used in your Xbox. Currently Microsoft uses Hitachi, Phillips and Toshiba DVD drives in the Xbox 360. Only the Toshiba and Hitachi drives have firmware updates.
4. Connect the DVD drive to your PC with a cross-wired SATA cable interfaced to a compatible SATA port. Confirm that the video cable is connected to the Xbox so that it won't turn off during the flash process.
5. Hold the two loose wires of the cross-wired cable together and press the "Start" button on the Xbox. Separate the wires immediately when the green light begins to flash on the front of the Xbox. The light will begin to flash quickly and the drive will begin to spin as it enters mode "B."
6. Turn the PC on and allow it to fully boot from the DVD drive. If Windows appears to fail the boot, eject the DVD and it will finish booting. You've successfully flashed the drive.
7. Reassemble the Xbox and enjoy playing the backup of your favorite game. Sources: http://www.ehow.com/how_2316522_flash-xbox-dvd-drive.html
Mar 10, 2010 | Buck Legendary: The Box for Xbox 360
I have just bought a brand new game and it has taken about 30 attempts to even load it kept saying open tray. Has loaded updates but when i get the play game on menu it then tells me to re-boot or clean...
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Nov 11, 2009 | Microsoft Video Game Consoles & Games
Xbox 360 reads dvds but not gamers,why?
The Game and DVD requires different process.
80% of the time a weak laser will read dvd but it will
not load games ,
The laser needs to be replaced . They're cheap 20.00-30.00
and not hard to install yourself if you want to save some money.
Or you can have a shop swap it out for 80.00-90.00
If you have any questions just comment and ill respond.
Rob
Oct 14, 2009 | Microsoft Xbox 360 Console
Dvd error
You will need to have your dvd drive replaced. Check for repair services on this site.
Jan 16, 2008 | Microsoft Xbox 360 Console
Error Message
Be sure to wipe clean around inside hole on 360 game disk it has info laser scribed that tells the system what game it is.It might also need a laser adjustment.
Dec 26, 2007 | Microsoft Xbox 360 Console
New Xbox 360 disk drive doesn't play games
well my friend thats because each xbox 360 drive is unique for each console so it only works on the original console, to solve this you have to flash the firmware from the old drive and put it the new one, there are many sites explaining it just google it.
Sep 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
839 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
