Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
Sony 65 inch
A few months ago I started noticing that my picture would fade out completly to a blank screen for about fifteen to twenty seconds every once in a while..I thought at that time that it was probably the cable service.Last night it started doing it over and over again every twenty seconds or so. I checked to make sure all the wiring was secure.I also checked every other video input one through six and the same thing happened on each one of them,including the dvd input I ran a cd and the same thing happened.The tv green light does stay on and the cable box channel number stays the same with no error code,as it does when we have an interruption in cable service.
  • Sony Master
  • 8,617 Answers
Do you loose the screen completely to a black screen, or does the video just drop out to blue screen or snow?Do you still have audio?
Posted on Jan 16, 2008
6ya staff
SOURCE:
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Rca d52w26 hdtv, work's fine for fifteen to twenty minutes. then screen fades away go's blank, the sound and channel's still work. help!
Replace the deflection board. You can get a replacement deflection board from www.tvrepairworld.com which also contains instructions on how to remove and replace the board.
Apr 16, 2010 | RCA R52WM24 52" HDTV Projection Television
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL [email protected]
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
I get curved red lines and then screen goes completely red and no sound
This is symptom of defective red picture tube in TV that needs to be replaced.
Let me know if you want to replace it by yourself to provide you part number info or call tv tech to do the job.
Thanks.
Nov 30, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Sony 52 inch projection Screen keeps shutting off.
not if it keeps repeating the same cycle over and over..it cost 300 once and if you have it fixed again thats another 300 and if it happens again so on and so on....
Feb 04, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Gray faded look on top to picture
It can be the plastic anti polarizing screen that covers the display.
Often it causes grey or red shadows on top of the picture.
Sep 15, 2008 | Toshiba 56H80 56" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
