Question about HP Compaq Evo Notebook N600c
COMPAQ EVO n600c DIsplay back light out
My daughter dropped her laptop and when she booted up the screen was dark. You can barely see the images. I hooked it up to an external monitor and all the functions are normal with the exception of the LCD's back light. Any help would be appreciated.
Dennis
  • DocMud Jan 16, 2008
    I am positive the back light bulb broke. We have another old EVO n600 with the same screen. I will remove the broken one and repalce it with the working one. That laptop has a MB problem.
    The screen bezel seems very determined to stay in place. I have removed all of the screws I can find but it still wants to stick
  • Anonymous Mar 21, 2014
    I dropped my ASUS Q200E. The screen does not display images. When I hook to an external monitor the image is displayed on the monitor. I can even get a touch screen response showing on the monitor when I touch the notebook screen. How can I get my image back on the notebook screen display?
    Brigadier General:
  • HP Master
  • 3,614 Answers
Your liquid display has been probably damaged because of dropping it down, laptop LCD screen is one of the most delicate part of a laptop, it needs a tender loving care from the user when we just only cleaning it surface with a provided cleaning solution for it.
You said that it was dropped its much probably that your laptop LCD screen broke. I had the same experience like you when my sister pulled the strap of my bag were my laptop was there i place on top of my cabinet so that she cannot used it when I'm away. But she sees and because she wanted to play games she pulled the bag down and my laptop bangs on the floor.. And it was broke.
For you u can still bring it to the service center to replace your LCD or for some availabity of stocks you can order it directly from the Main service center probably US.
When i hear that story from you the memories of like what also happen to me came back.. tsk..tsk... So when it happens I learn and give me a lesson that my laptop is much safer when i putting it and do my work with my laptiop on the floor. And hide and keep it under the bed with pillows on guard.
tnx
-micro
Posted on Jan 16, 2008
  • micromaster
    micromaster Jan 16, 2008
    There must be a spring attached to the panel mount it possibly attached to clip on lock type, carefully find somewhere that clip which make the screen still fits to the housing.
    By the way whats the problem of the another laptop that you have an MB problem??
Compaq Evo N600c Laptop over 5 years old but has been working fine. About 2 months ago the screen went dark (bad lamp?) so been using an external monitor. Turned it on this morning and it started to boot...
Do you see any lights on the laptop that are on? If you see any lights and only a black screen, then more than likely your video chip on the motherboard has gone out. Some local shops might be able to replace the motherboard it might be cheaper than buying a new laptop. Good luck
Feb 25, 2011 | Compaq Evo N600C PC Notebook
Adjust screen brightness evo N600c
using the blue Fn key(usually on bottom left to side of space bar)..look at Funtion keys on top, under the screen. One of them(F5 or F8) will have a blue sun image or a monitor image to increase or decrease the brightness. press the Fn key first, then the one that increases brightness until it's good .
Nov 28, 2009 | HP Compaq Evo n600c Notebook
Evo N600C, display is 'dim' and mainly 'red'
There is one CCFL lamp on the bottom edge of the LCD screen.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 04, 2009 | HP Compaq Evo Notebook N600c
On start up of my compaq evo n600c the screen
Have check by a technician because the ribbon cable that runs behing the screen is loose.
Jul 16, 2009 | Computers & Internet
All white screen on compaq n600c
When you hooked up external monitor, did you switch to it via "Fn" keys?
If it did not help, then it's GPU ot North Bridge on the board that needs service.
Mar 19, 2009 | HP Compaq Evo n600c Notebook
Video Display on TV
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
37
Sep 15, 2008 | Compaq Evo N600c Notebook
Reboot
You can insert the OS installation CD and hit F11 or F12 to get to the boot menu. The you can wipe out your hard drive and put a fresh copy of windows on it.
Apr 18, 2008 | Compaq Evo N600c Notebook
Replace CCFL lamp
You may not need to replace the ccfl lamps, usually the problem is the inverter that supplies the voltage to the lamps
Apr 11, 2008 | Compaq Evo N600c Notebook
Evo n600c problem
Try VLC player, or media player classic.. mess with the internal settings to force a different refresh rate or renderer..
Feb 08, 2008 | Compaq Evo N600c Notebook
Compaq evo N600c monitor problem
inverter or lcd tube problem.thats the reason
Dec 07, 2007 | Compaq Evo N600c Notebook
HP Compaq Evo Notebook N600c Logo
380 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
