Question about Salton Melitta 45 Cup Stainless Steel Urn
Melitta 45 cup Stainless Steel Urn
When it's plugged in & you think it is making coffee - but all you have is hot water. The water never travels through the stem to wet the coffee? Any trick I can try?
  • Lebarb Jan 16, 2008
    I'll give it a try, thanks!
  • staceyserdah Dec 04, 2008
    Can I make cocoa with this machine?
We have the same problem and what happened is that the bottom of the stem became bent and will not seat properly. We have a second Melitta urn and when we use the stem from that one it works correctly. We tried to order a replacement stem from the company that now supposedly makes the parts but they told us it was on backorder four months ago and we have never been able to get one. So I would suggest you get out your tools and make sure the bottom of the stem is as round as possible.
Posted on Jan 12, 2009
Make sure that the stem is seated properly, right in the center of the bottom of the pot before trying to perk.
Posted on May 03, 2008
  • 2,039 Answers
Use a decalcifier to remove calcium buildup calcium is like concrete dont forget rinse the machine very good after that stuff is very corosif vinergar not strong enought dont forget to rate this cheers.
Posted on Jan 16, 2008
When I brew a pot of coffee all of the grounds do not get wet Why?
Hello, Vicky -
It will help in answering your question to know the make and model of your coffee maker. You can choose Comment and add that information in the Comment box.
As a general answer, there could be 2 reasons for all of the coffee grounds not to be wet:
* You may be using a dark roasted coffee, which has a high amount of surface oils , making it difficult for the water to wet all the ground coffee beans during the brewing process. If so, you may need to follow the "hot bloom" method when setting your coffee maker up to brew. Watch the video here:
https://www.bruer.co/blogs/news/113462276-the-hot-bloom-method-eliminating-dry-coffee-grounds
* The spout for the water to dispense in your model of coffee maker may have become positioned off-center
Along with only partially wet coffee grounds does the brew seem weak?
I assume you have already checked the user manual for your coffee machine to find if the partially dry coffee grounds issue is addressed in the Troubleshooting section. You may wish to visit the website of the manufacturer of your coffee machine to find if the problem is covered in FAQs or Troubleshooting for your model of machine.
Best wishes.
Feb 15, 2018 | Coffee Makers & Espresso Machines
I have an 8 cup perculator that perks but does not make coffee.. somewhere it is not filtering to the top to run through the coffee. but water gets very hot... whats wrong with this ?
Hi. It is very importent, that the spring is in place. With out it the stem is like floating around the bottom of the pot, thus not forcing the water up the stem to the spreader. I hope this is the problem. Good luck. Ron
Aug 26, 2010 | Faberware Coffee Makers & Espresso...
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
We have several Farberware FSU255 coffee urns in church kitchen usage. Have had some problems reported with the water not perking through the coffee grounds resulting in only hot water and frustration....
I have the older style 55 cup coffeemaker. It is critical that the coffee grounds basket compress that spring on the stem. Pull the spring upward alittle until the basket rises slightly above it's seated position until you put the lid on and it will put the necessary pressure on the stem down in the heater element hole. Also there is what appears to be a loose washer on the bottom of that stem (where it fits into the heater unit) This washer must be free to move around and it acts like a check valve to prevent water that has "perked" up the stem from falling back down the stem.
Nov 11, 2009 | Faberware 12-55 Cup Coffee Urn
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Farberware Coffee Urn won't make coffee
Be sure that the washer at the bottom of the pump stem remains loose.
If coffee grounds lodge in this area, remove under running water or with
a wooden tooth pick. Dan
Dec 27, 2008 | Faberware 10-22 Cup Coffee Urn
How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Nov 14, 2008 | Regal Ware 426473 Black Satin Coffee Urn...
How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
Aug 09, 2008 | West Bend (58036) 36-Cup Coffee Maker
No brewing
probley needs cleaned! i use a 50/50 mixture of white vinegar and distilled water. run the machine as you would if making coffee. may have to repeat the process a few times.remember after cleaning to run a few cycles of clean water to clear the system
Dec 05, 2007 | Gaggia Espresso De Luxe Espresso Machine
WestBend percolator coffee maker 58002 does not circulate hot water
Sounds like the thermostat is weak and turning off at too low of temp.
Mar 08, 2007 | West Bend 43536 Coffee Maker
Coffee Makers & Espresso Machines Logo
228 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gil Shultz
Jay Plesset
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
