Question about Nikon Macro Speedlight SB-29 TTL Ring Light Flash
SB-29 speedlight overflash
I have the SB-29 speedlight. Until about 1 week ago it worked fine. Now, whenever I use it in the Macro setting, it overflashes and the picture is white. Any suggestions?
    Champion:
    Scholar:
  • 216 Answers
Go Manual.
Set F Stop to higher number.
Can also lower the ISO.
[email protected]
Posted on Jan 18, 2008
6ya staff
SOURCE:
DOES IT WORK WITH NIKON D300S
Yes, though it's an older flash unit and cannot be used in the iTTL mode. The "Other Flash Units" section of the D300s manual (page 350 in my copy) lists the modes in which the flash may be used. Another concern is that the flash may not work well with certain lenses. The "Usable lenses and cameras" section of the SB-29 manual (page 5) discusses this.
If you need manual, you can download the D300s manual from
http://support.nikontech.com/app/answers/detail/a_id/16525/kw/D300S/r_id/116678
and the SB-29 manual from
http://butkus.org/chinon/nikon/nikon_sb_flashes/nikon_sb_flashes.htm
Jun 25, 2011 | Nikon Macro Speedlight SB-29 TTL Ring...
I have a Nikon D40x with a Nikon Speedlight SB-800. The speedlight is not working. I have the camera on, new batteries in the speedlight and speedlight on. Not powering up. Is there some secret battery...
With new batteries in the flash, and it being off camera what happens when you press the test button. If still it does not flash call Nikon 1-800-645-6689
Aug 14, 2010 | Nikon Speedlight SB-800 TTL Flash
Speed light is completely dead, have replaced
Contacts are broken, you will have to send it in.
Mar 18, 2010 | Nikon Macro Speedlight SB-29 TTL Ring...
Will this work with D2X
The SB-29 was made to work with film cameras. It will work on your D2X, but only in manual mode.
Mar 22, 2009 | Nikon Macro Speedlight SB-29 TTL Ring...
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-27 TTL... Problem
    This flash unit will flash the red light until the capacitor is charge. Also the mode your shooting will flash. What exactly is flashing?
    Aug 11, 2008 | Nikon Speedlight SB-27 TTL Flash
    Ready light on my SB-800 speedlight
    put in a fresh set of batteries. The ready light won't turn on until the flash capacitor is fully charged. And if your battery is weak, it can take very long (minutes!) to fill the capacitor. You still can fire the flash even it is not ready, it will just dump whatever power it stored in the capacitor.
    Jun 12, 2008 | Nikon Speedlight SB-800 TTL Flash
    Nikon SB-29s macro speedlight
    Trigger coil or a flash tube. Flash tube is easier to replace so try to replace that first. Caution before you do anything else when you open the unit locate the main 330v capacitor and discharge it before you work on the unit !
    Mar 22, 2007 | Nikon Speedlight SB-600 TTL Flash
    Built-In Speedlight (Flash) will not retract
    I haven't heard of this problem but compliments of velocityreviews I came up with this. Follow the instructions below to attach an external Speedlight. Refer to your Speedlight manual for detailed instructions regarding Speedlight operation. 1 Make sure that both the camera and the external Speedlight are turned off. 2 Attach the Speedlight to the camera accessory shoe. 3 Turn both the camera and the Speedlight on. 4 Set the external Speedlight zoom head to an angle wider than 28 mm. If you are using a Speedlight with Auto Power Zoom, set the zoom head angle manually. The COOLPIX5700 does not support power zoom. 5 Set the external Speedlight flash mode to TTL. At this setting, the amount of light produced by the external Speedlight is measured by the camera?s photocell, and the flash shooting range adjusted automatically to ensure optimal exposure. D-TTL flash control (available with the SB-80DX, SB-50DX and SB-28DX) is not supported. 6 Take the picture If the Speedlight Options: Speedlight Control option in the SET-UP menu is set to Auto, only the external Speedlight will fire. If this option is set to Int & Ext Active then the external Speedlight and the builtin Speedlight will fire at the same time. The COOLPIX5700 does not support AF-assist illumination, or red-eye reduction using the red-eye reduction lamp on the external Speedlight. At a setting of STBY (standby), the Speedlight will turn on automatically whenever the camera turns on but will not turn off automatically when the camera turns off. Exact functionality varies with the Speedlight in use. Refer to your Speedlight manual for details. I hope it's of some help BMW
    Jul 07, 2006 | Nikon Coolpix 5700 Digital Camera
    Nikon Macro Speedlight SB-29 TTL Ring Light Flash Logo
    167 people viewed this question
    Top Nikon Cameras Experts
    Ric Donato
    Ekse
    pictureman4u
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
