Question about Linksys EtherFast Cable/DSL Router
Port Forwarding hi, I configured my Linksys router for Remote Desktop through port forwarding. At present I have two computers in my network which have been configured port no. 2007 and 4000 working perfectly. But when I tried another computer, its not happening. I am not able to access the computer by using the port 4003 forwarded to the respective IP. Kindly help me regards, Sooraj
  • Rialda Jan 31, 2008
    Thanks for the try Bear001,
    Actually, I could solve the problem. I changed the rdp port number as 4003 in the windiws registry then as usual I configured in my Linksys router. It works fine now. Thanks.
  • 239 Answers
Hello Just wondering If both are on the same work Group in the network settings. (Same Name) You probably did that already but if not give it a try and maybe your forwarding will resume and work properly. Hope so. Thanks
Posted on Jan 16, 2008
Http 192 168
If you are trying to access the DVR server from outside your network, you need to use port forward, in that way you will use your DVR client to connect to the router's public IP, the router will be forwarding the port the video system use to the computer, just configure the computer's IP in the router's port forwarding configuration.
May 18, 2013 | Cisco Model EPC3925 8x4 Eurodocsis 3.0...
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
How do I configure my router for port forwarding
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For Linksys Router.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
For D-link router
You will see Network settings in the left hand side panel of the page.
Click on Network settings and go to the Advanced TAB at the top.
Now you will find the option. Pot Forwarding in the left hand panel.
Here you can open the ports on the router.
BELKIN wireless router
Click on Virtual Servers under Firewall in the menu on the left
Click Enabled. Type a general description of the application i.e.. Remote Desktop. Type the port(s) specified by the program manufacture for both of the Inbound port fields. Select TCP, UDP, or BOTH for the Type.Private IP address: Enter the IP address of the computer you want grant access too. Type the port(s) specified by the program manufacture for both of the Private port fields.Click the Apply Changes button.
Click on Port Triggering under Advanced menu.
Change the value of Port Triggering Timeout as 20 Click on Add Service. Specify a Unique/User Defined name under Service Name. Ex: Mails, VPN. Specify the Service User as Any (if all the computers in the network are port triggered or if a single computer on a network is port triggered specify the IP address of the computer). Select the Service Type of the port to be triggered
Ex: TCP . Specify the Trigger Port (The port to be triggered). Select the Connection Type of Inbound Connection. Specify the Starting and Ending Port for Inbound Connection. Click Apply to accept changes. Your router is now set up for port triggering..
Jan 19, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
BL-C131 port forwarding.
So you've configured port forwarding on the router. Do you have any anti-virus applications installed or have your set an exclusion in Windows firewall?
Feb 01, 2010 | Panasonic BL-C131 Network Camera
How do I do port forwarding with one static IP to put my address in my other computers . I need to shadow into with VNC after I install address on my computer is port forwarding marked on the menus are...
Find the IP-address of the computer that you want to accept VNC connections.
Access the router's web-interface.
Find its web-page for "port-forwarding".
Define 'TCP' port '5900' to be forwarded to the IP-address that you found.
Save the settings, and restart your router.
Hopefully, Verizon's FIOS network does not "block" all 'TCP:5900' traffic.
Nov 17, 2009 | Linksys Computers & Internet
Settings on Linksys router for the DCS 5220 to view remotely and settings on Securicam
Configuring your Linksys router for remote desktop is a task that's needed before you can access your computer from outside the network. If you plan to connect to your remote desktop machine from the Internet, you need to configure the router to allow traffic to the PC. Linksys is a common router used on home networks for wireless and LAN configurations. Configuring your router to allow port forwarding to a remote desktop only takes a few steps through the graphical user interface.
  1. tep 1 Open your browser window and type the IP address of the router in your address bar. This opens a window for the username and password needed for access to configure the router.
  2. Step 2 Click the "Applications and Gaming" tab on the opening screen. This opens a window with a list of ports of which you can open for access on your network.
  3. Step 3 Type "Remote Desktop" in the application textbox.
  4. Step 4 Enter "3389" in the "Start" and "Stop" port ranges. This port number is specific to the remote desktop application.
  5. Step 5 Leave the value of "Both" in the protocol listbox.
  6. Step 6 Type the IP address of the internal machine on your network. The IP address is the machine running remote desktop. When traffic from the Internet reaches the router, it forwards the request to this IP address.
  7. Step 7 Check the "Enabled" checkbox and click "Save Settings."
  8. Step 8 Close the browser window.
Nov 14, 2009 | D-Link DCS-5220 Network Camera
Port forwarding & Remote Management setup on Linksys WAG200G
here is how you set up port forwarding:
1. log into the router;
2. Click the Applications & Gaming link near the top of the page. 3. You should now see a new menu. Click Single Port Forwarding or Port Range Forwarding.
4, Enter sth like: HTTP; 80; 80; TCP;; check
5. When you're finished, click Save Settings near the bottom of the screen to save your changes.
go to administration-> remote administration to set up remote management
Remember, remote Administrator requires you to forward the 4899 ports.
Mar 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
Remote access
you would need to forward port 3389 and make sure that the ip you're forwarding it to has remote desktop enabled for at least one user.
(start--> settings--> control panel--> system--> remote desktop)
Mar 25, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Parker Vision Router WR1500
You need to forward the remote desktop port to your server. The Remote Desktop port is 3389. Go to the port forwarding section of your router and find out your Server's network IP address and assign it to forward the Remote Desktop port of "3389". Save your changes and try connecting again.
Sep 06, 2007 | ParkerVision SIGNALMAX WR1500...
Linksys EtherFast Cable/DSL Router Logo
120 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
