Question about HP LaserJet 2100 Printer
Damaged Board Component
I have an HP Laserjet 2100. The unit has a damaged component on the engine controller circuit board. The silkscreened designator on the board is "PS201", The component looks like a resistor and is marked "5000". Can anyone help in determining what the replacement part may be? Thanks
  • 417 Answers
Hi unfortunately you will have to replace the whole board. If you go onto Google and type in the search bar "HP Part Surfer" and select the site that goes onto the part surfer. Select language then select the machine type and then you will be able to search for the correct part and it will display the part number.
I don't know where in the world you are so you will have to find a HP supplier and order the part.
Hope this helps
Thanks J
Posted on Jan 16, 2008
Can't get the unit to give any volume or sound. Properly connected
check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 24, 2016 | Televison & Video
No volume hp flat panel model hp lc 3040n
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 29, 2014 | Televison & Video
How to solve scanner error 5 in HP LASERJET 3055?
The stepper motor controlling the scan arm is defective. Replace motor or entire unit.
Aug 07, 2014 | HP LaserJet 3055 All-In-One Printer
55.00.00 DC Controller error
Basically The engine is not communicating with the
formatter.
1. Turn the device off and then on.
2. Verify that the flat ribbon cable between
the ECU and the formatter PCA is
connected correctly.[do extra care while removing from board easily crack at ends]
3. If the message persists, replace the
ECU[check on board and track,component damaged-burned its fixable].
If the message still persists,replace the formatter.{before replacing it can be fixable by hot oven/hot plate method }
inquiry send on http://electronicdoctor.weebly.com
0740d731-eaf6-439f-a99c-b738dfa73141.jpg formatter
156d8d89-0eee-4c56-aad5-db018e3e9d12.jpg ecu
Apr 03, 2014 | HP LaserJet P3005n Printer
Why did the Q6 component blow on the circuit board
I`m not sure which component you refer to by "Q6", but typically on the Maytag Neptune washer it is the resistors associated with the door lock assembly which burn out on the "machine control board" (not to be confused with the "motor control board" located under the basket/tub inside the cabinet). It should look like the image below.
You can usually examine the control via a visual inspection to confirm or dismiss any damage. Look for any sign of burnt resistor's, specifically one identified as R11 and one as R75 they are both part of the lock circuit and if damaged will prevent the washer from draining and spinning properly because the door lock won't engage. The control will need to be replaced if damaged as will the latch wax motor. (Unless you can identify the value of the resistor`s and take a gamble on a repair)
Check with a local or on-line part depot with your model number for specific part number's. Hope that help's, let me know. Thank's for visiting "fixya" and if this was helpful please leave a rating for the info I provided. Thank's again and good luck. macmarkus :)
Feb 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Transistor source and price
rockford fosgate use hexfets.they are made by international rectifier and are available from toronto. they are n and p channel devices.they are not bipolar transistors...
Jun 16, 2009 | Rockford Fosgate Punch 401S Car Audio...
Ptv915 won t turn on; led blinks 3 times, then continues blinking 2 times over & over. Tv shut off with ''snap''.
HI, your power supply circuit board is damaged and, you will need to replace this damaged component asap if possible. this will restore your units operational value.
Jun 05, 2009 | Philips Televison & Video
HP 2100 LaserJet, was functioning ok, now won't power up, power to AC plug is ok ... Is there a fuse somewhere ? Jim
Remove rear cover and fuser.
Blown fuses usually point to a bad power supply which is the circuit board under the fuser.
Feb 07, 2009 | HP LaserJet 2100 Printer
Laserjet 2100 Won't turn on!
Yep, the power cable can be faulty, test a different one on a different socket. Try also playing with the power connector on the printer.
If the power cable is fused, like for example in UK, then check the fuse.
If it still does not give any sign of life, then there is a fault on the power supply board, inside the printer, usually the power supply fuse. Part is about $45 refurbished/$55 original .
If the problem is not the fuse you will need to get a technician testing on board component, and probably replacing a faulty resistor or capacitor.
Sep 26, 2008 | HP LaserJet 2100 Printer
HP LaserJet 2100 Printer Logo
83 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
