FixYa.com
Tags:
Toshiba PCX 5000 Wireless Cable Modem Gateway Bridge/Router
Toshiba PCX5000 (Cable Broadcast failing)
By Ranny - usenet poster
Hi- We have a Toshiba PCX5000 cable modem/wireless router combo.  The
wireless portion fucntions fine, and we receive a strong signal
anywhere we want to use our machines.  However, the cbale input/output
seemingly fails quite often.  That is, the "cable" light goes out and
we lose connectivity.  The only fix I can find is to reboot the device by
unplugging it, and this works ~50% of the time (and never on the first
try).  Otherwise, we just have to wait unitl the thing decides to pick
up the cable feed again.  I've tried to eliminate some variables and
have determined:
1. It is not the coaxial cable itself.
2. It is not the styrength of the cable signal at this particular jack
or in our house overall.
Has anyone experienced similar problems?  Any remedies?  Unfortuantely
I do not have a receipt for the modem, so if anyone has experience
with Toshiba warranty/exchanges that might be helpful too.
Cheers,
Drew
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Melissa
Melissa - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
And exactly how did you determine that it's not the most likely cause?
What test equipment did you use? What parts did you replace? Did you
disconnect the inside cabling prior to the first splitter, and try the
modem there?
It's far more likely that the issue is your inside cabling than anything
else -- bad splitters being ahead of bad coax. Second on the list,
behind both sub-issues of the first, is plant problems. The modem being
the issue comes in at a distant third. A very distant third.
In the unlikely event that it is the modem, the only fix is to replace
it.
Warren H.
Disclaimer: My views reflect those of myself, and not my
employer, my friends, nor (as she often tells me) my wife.
Any resemblance to the views of anybody living or dead is
coincidental. No animals were hurt in the writing of this
response -- unless you count my dog who desperately wants
to go outside now.
     Blatant Plug: "The Simpsons" 2005 Calendars and Books:
     http://www.holzemville.com/mal l/simpsons/books.html
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
I've gone through 3 in the last year.  It is not able to keep a
connection up.  The current one reboots evey hour or two.  The
previous one would lock up every day or two.  I not sure which is
worse!  Toshiba sent the replacements out in the spring, but they are
nolonger returning calls or email.
I don't believe the have a way of upgrading the firmware.
Can you Help with these Other Network Devices problems?
more mb uses
sir my pc uses more mb. when i... Answer This...
Packateer 1700 PLGs
how to load plugins Answer This...
rotax 100cc go kart engine
What is the feul mixture and... Answer This...
tcp error
(tcp_Error) how to remove on... Answer This...
my mt6227
how can i add a service... Answer This...
Repair Service
Find Other Network Dev. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
