I have a whirlpool self cleaning/accubake system(mdl: RS675PXGB0). when I try to increase temperture by pressing the arrows the temp goes down. I am pressing the right controls. also sometimes the timer doesn't work properly , when I press to set timer the clock wants to change times this doesn't happen to often.by the way the temp control is at 350 degrees when i press the bake control & them it decreases when I press either to increase or decrease temp.this is an electric range.
You need to replace the ( e o c ) the clock ) it's lost the ability to comprehend your needs .. the 350 start up is normal / but the up arrow should increase temp .. time should not be changing .. replace the clock / this part # 4452240 is n l a ) your clock can be sent in to be repaired / only . hope this info will help .. & 238.00 last price on this clock .
