Question about Casio Pocket Viewer PV-200A
Problem with Expense Amount Format
Everything is working fine except for the Amount field in the Expenses window.
The format is 00,00
Note the separator is a comma, not a decimal point.
I have tried to change it and can not.
The result is when I enter an amount such as 60.02 the result reflected is just 60 which is on the left side of the comma. Thus it shows
60,00
Any ideas on how to get around this would be greatly appreciated.
Thanks in advance.
Karl
SOURCE: Changing result display from fractions to decimals
Struggled with this and found answer on about page 19 of the instructions on the Internet. Answer also appear on paper instructions under: "Displaying Calculation Results...etc just under "Note" Trick is you must have calculator in "LineIO" mode For setting MODE see "Calculation Modes & cal. Setup in paper instructions.
Posted on Sep 01, 2007
flexion1
  • 737 Answers
SOURCE: Change amount exceeds limit
Hi. What brand and model number?
Does it do it with with other payment methods e.g credit, or just cash?
Mark
Posted on Oct 30, 2008
  • 8074 Answers
SOURCE: how to convert the result of a calculation to
Press the [S<=>D] key.
Hope it helps.
Posted on Nov 18, 2009
Testimonial: "thanks..i found it very helpful"
  • 8074 Answers
SOURCE: I have Casio fx-83ES. I'm using it in Mode 2 -
You can configure it as you wish. Press [SHIFT][MODE] to access the (SETUP) configuration screen, then select [8:Norm].
You will be prompted to choose Norm1 or Norm2. To help you find out which is more appropriate to meet your concerns, I am inserting a screen capture from the manual.
Posted on Jul 18, 2010
  • 8074 Answers
SOURCE: How do you change Casio
There are three ways to enforce the changes, and it is quite impressive for this calculator. Yet for you it is not enough. I am sorry but I am not aware of another way.
Maybe, just maybe, if you fixed the number of decimal digits to 0, all your results will be integers, and there won't be any reason to convert any result to a decimal and the problem will be solved.
Posted on Sep 12, 2011
How do I reset the time on my ftbit
  • Clock/Time (Fitbit Ultra only)
    • The current time can be viewed on the Fitbit Ultra's display.
    • The time can be displayed in 12 hour format (e.g., 5:00 PM) or 24 hour format (e.g., 17:00). You can adjust this setting on the Edit Profile page, which affects the displayed time on the Fitbit Ultra, graphs, and input fields across the site.
    • The clock display can be disabled from the Fitbit Ultra setup screen.
Nov 09, 2014 | Fitbit Zip Wireless Fitness Tracker
I've heard the term "expense ratio" referred to in terms of mutual funds. What does this term mean?
An expense ratio is how investors compare different expenses across different funds. The expense ratio is the 12b-1 fee with the management fee and any other fund expenses and then this total is divided by the average daily net assets.
Aug 19, 2013 | Finance
DELL DIMENSION DVD ROM CODE 10
please install dvd driver cd and software
May 07, 2012 | Dell Computers & Internet
What is .sdf file
The .sdf or standard data file is used for storing data in a structured format; uses fields of fixed lengths to store values; can be imported and exported by various database and data analysis programs; commonly used for transferring data between different programs.
Sep 03, 2011 | Oracle 10g Database Standard (ODBSEONUPP0)
Have a new 8 gig memory. Shows full before all pictures load, should have loads of room?
I would format it using your computer, then try loading in your photos again.
In Window, go to your file explorer, right click on the drive and click Format.
http://www.blogsdna.com/wp-content/uploads/2009/01/format-usb-drive.png
It's ok to do a 'quick format'.
This will delete everything on the drive.
Now try loading on your photos, and see if that made a difference.
Mar 07, 2011 | Philips 7FF2CMI/00 Digital Photo Frame
Format to factory settings
u must got windows xp disk
Nov 13, 2009 | Computers & Internet
They are probably in a format that the pda can not handle.
Sep 14, 2009 | Palm Tungsten E2 Handheld
Hard Drive Problem
This has happened to me once. I unplugged it overnight and plugged is back in and everything (Except for the for the DVD that was being written when it malfunctioned) Worked fine. I suspect that a Capacitor is going bad but it’s still working (for 4 months) and I will put off any real trouble shooting until it fails hard.
Apr 25, 2008 | Panasonic DMR-E85H DVD Recorder
How can i export tally data to excel format?
Export to Excel With new release now you would get one more options while exporting data. One added format option is Excel format. excelexport.jpgIf you export in this format then file would be saved in xls format. More over if you put Excel formating option to Yes then tally would automatically format the data in presentable format. Tally would automatically bold the headlines and main fields for you and format data in a good way. Take a look at excel snapshot of balance sheet exported from Tally.
excelexport2.jpgThe special thing here is that you can do the calculation on any amount figure or any row or column, which was earlier not possible. The only drawback which i could find was that amount figures are not right aligned which is must for numbers for easy calculation, although you can do it by selecting the amount figures and putting them right aligned.
Feb 27, 2008 | Computers & Internet
Phillips Gogear 30G Playing problems
The device itself is not faulty. This is Microsoft's fault, not Philips'. Microsoft no longer supports Jukebox. Use Windows Media Player instead.
Some of the songs may have Digital Rights Management (DRM) encoding that the player will not support (once again, Microsoft's fault, not Philips). You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
-Tha Mp3 Doctor
Oct 29, 2007 | Philips GoGear SA178 MP3 Player
Casio Pocket Viewer PV-200A Logo
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
