Question about Intel D845GLLY Motherboard
The power on my pc keeps recycling
I recently bought a new p35-ds4 mobo, hooked everything up, turned the power on and all the sys fans come on for a sec, but then it just shuts off and keeps recycling. it doesn't post or anything. i noticed the cpu fan doesn't come on right away and i tested the fan and it works. i don't know if that's normal or not. i even tried taking the mobo out of the case and tried posting with just the cpu and mobo and the same thing happens. i checked the tray and there are no loose screws or anything shorting it out. i also tried reseting the cmos and still not luck. do i have a bad board or cpu?
My mother borad is d845glly destop turn on but harddisk light is continuse on but monitor is led is blinking fan is working normal but display not found what hapen
Posted on May 20, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Remove all hardware except RAM n CPU and then try it if the system gives you a disply then add all hardware 1 by 1 and keep checkin this way you can find the problem with the harware compatibility if the system wont disply then check the mobo for RAMs and CPU respectively if the problem presists then you have the BAD BOARD.-
Posted on Jan 16, 2008
    Brigadier General:
  • 3,614 Answers
Yah! you got problem with your cpu, the processor is overheating that why your computer release it power after you loaded the POST, when it already read your hardware attached it detected that your processor temperature is overheat.
Try to go to BIOS setup and go to the CPU temperature settings let your machine run only on BIOS setup and you will see that your cpu temp is going up high, normal should 40% but if it reaches 65% and above it overheat. Unplug the power cable and remove the heat sink on the processor and try to touch the processor and possibly the heat can hurt your skin.
By the way does your cpu is Pinless type? If so we are on the right track for the problem,
I have an Antec full tower with a 350W power supply it seems somewhat old...i hooked everything up inside and tried to turn it on but it would not turn on any suggestions?
First, is there power from the power supply? Is the power supply turned on in the back? If there is powere to the Mobo, then the mobo is likely the problem. The cpu fan fan should spin if there is ower to the board.
Apr 20, 2010 | Computers & Internet
PC won't boot (no signal and no beeps)
check the board for blown capacitors. I have found many boards from power circuits to motherboard with popped capacitors over the past 5 or so years. replace them and tada, it lives again. I've been successful several times with this operation. Please see the picture below for a guide to finding bad caps.
Jan 02, 2010 | Intel Motherboard
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur BP....it;s not worth this much effort....
the kind of work u have done...it seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | Computers & Internet
Newly built system will not power up!
It seems like you have bad MOBO. I recently ordered all the stuff to build 2 new systems. Built the first one, no power, just like yours. Moved everything to the 2nd MOBO, everything worked. I did a RMA on the DOA MOBO. Got the new one and it fired right up. Sometimes you just get bad stuff.
Please don't forget to rate this solution.
Jun 09, 2009 | Gigabyte GA-8SQ800 Motherboard
My Pc wont boot no signal in my monitor Help!
May be your in second HDD, you didn't set the jumper up. There are some more settings you will have to configure in the BIOS menu. in the BIOS, you should set the primary HDD as the master and the second(newer HDD) as the secondary. Then it should boot without any problem but if the problem persists I don't know what to do next.
Mar 08, 2009 | Abit IP35P Motherboard
Stand by
Standby does not turn off the computer. It reduces power consumption but does not turn the CPU off or the power supply. Because the cpu is still on the cooling fan stays on to cool it. If you want it to turn the fan off or be silent I suggest using hibernate or shutting it down completely.
Feb 01, 2009 | E-Machines (308714) Motherboard
Problems with P35neo2
Check your M/board manual for setup if it should have an 8 pin power connector you will need a power supply to suit it if you continue trying without it you could also be up for a new motherboard and CPU
Aug 05, 2008 | Super Flower Computer Super Flower Cable...
New computer won't POST
have you tried different memory as no matter what the board says they don't like some memory .
also take the board out of the case and connect pwr supply.
cpu and fan ,video card , and 1 memory stick
no cables ,keyboard ,mouse or drives connected.
this is called bread boarding.
reset the bios jumper, then put jumper back.
and power up.
Mar 31, 2008 | Computers & Internet
Intel D845GLLY Motherboard Logo
93 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
