Question about Kenwood TK-3100K2 (2 Channels) 2-Way Radio
TK 3100, No communication, codes check out OK
I have added an additional TK-3100 2 channel radio, to the many others I use.
I have changed and confirmed the frequency and tone to match the others but, it will not communicate on either channel with any of them.
Was wondering if there is anything else I needed to do?
Thank you for you assistance.
Steve
  • Mike Michalko
    Mike Michalko May 11, 2010
    are the frequencies on the same channels as the other radios. Is there a PL code set on the other radios?
    Master:
  • 518 Answers
Try one of the side buttons to see if you can hear squelch noise. If so, hold it in then talk on an existing unit. If you can hear it, then the squelch code is wrong, if you still can't hear it, then the frequency is wrong or the unit is defective.
Geno
Posted on Jan 23, 2008
How do you change the channel on the AXU4100
Here is a link to the user guide, where you will find the available built-in frequencies, and instructions: http://acsspirit.com/brochures/ax_user_guide.pdf
You can also take your radio to a Motorola dealer and have them program it (custom) using Motorola software and cable designed for this style radio.
It could be as simple as enabling a private line code (PL code) in the radio. You may not need/want to change frequencies. Adding a PL code would block out other users on your frequency. You would not hear them, despite them still being there.
Best regards.
Dec 19, 2012 | Motorola AXU4100 (10 Channels) 2-Way Radio
I bought additional kenwood tk 2100 radios and they are not sending the signal to my existingones. The fcc numbers and interior tk numbers are the same. How to I get them on the same frequency.
To change the channel frequencies on your TK2100, simply press and hold the PTT switch ("talk button") and Monitor key, then turn the power on. Now press the PTT switch again. The light should change from orange to red and a beep should sound. Next, adjust the channel switch to the channel you wish to program. Now simply press the PTT button to choose between 4 to 8 possible frequencies, depending on your model.
You can find the manual and frequency graphs here: http://www.heritageresale.com/documents/TK2100OwnersManual.pdf
Aug 26, 2011 | Kenwood...
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
Unable to connect to my works existing network of tk-3100 w/tk380
The pl tones are wrong. It will not work unless you know the PL or DPL.
Jul 05, 2009 | Radio Communications
I need to program Kenwood TK - 3100. I do not
I may be able to help. Where are u at? You can contact me at zkudlacek@hotmail.com with your info.
S.
Apr 20, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
I need a owner's manal for my tk-260.
It wold seem that you have two (2) concerns:
  • user's manual;
  • battery charging - pls check output voltage of adapter/charger; pls check battery terminals.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Nov 02, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Yaesu Ft-60R with Kenwood TK-3107
ok guys!! i have gold for your prob huhuh
go to this website and u can get anything about all model TK
http://www.twowayradioearpieces.com/Programming-Cable-for-KENWOOD-C178-1.htm
Oct 31, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Tk-3100
Hi Tucaraca.
With the radio OFF, switch to CHANNEL 1, press the SQUELCH and the PTT at the same time. Turn ON the power switch while keeping the PTT and SQUELCH until the LED indicator turns RED.
Release the buttons and then press the PTT to CHANGE the FREQUENCY.
Press the PTT once each time until you get to the right frequency you desire. The 8 standard frequencies are as follows: 464.500, 464.5500, 467.7625, 467.8125, 467.8500, 467.8750,467.9000 and 467.9250 MHz. Once you get to the frequency you use, wait a few seconds and listen for the confirmation tone. Each frequency has a different confirmation tone so take note in case you need to program a second radio.
After you hear the confirmation tone, press the SQUELCH to confirm, and then press the SQUELCH again to lock the new frequency. Wait until the LED turns off, then switch off your radio.
Same procedure for CHANNEL 2.
WARNING: You must be legally licensed to use any frequency on any PLMRS such as the TK-3100 series. You must also apply for FREQUENCY COORDINATION and submit FCC form 601. FCC can impose steep fines and imprisonment if they catch anyone using an unlicensed radio on a controlled frequency. Visit FCC.GOV for more information.
Nov 27, 2007 | Kenwood TK-3100K2 (2 Channels) 2-Way Radio
Kenwood TK-3100K2 (2 Channels) 2-Way Radio Logo
130 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
