Question about IBM eServer xSeries 346
Server IBM X series 436 1 defunct 1 rebuilding
My problem is my server 1 is defunct 1 is rebuilding cannot boot up pls help me
  • Mike Hodgetts May 11, 2010
    Are you saying that a drive in a RAID is defunct?
    If so, how many drives are in the RAID and what RAID level are you using?
    Into what operating system are you trying to boot?
  • 58 Answers
SOURCE: defunct drive
You could rebuild the defunct drive with the raid program on your server.
i don't know your type and model of your server.
8488 or 8648 and the model 3 digits.
for this you need serveraid manager
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/docdisplay?lndocid=SERV-RAID&brandind=5000008
please do not update your firmware or drivers at this point if applicable.
if rebuild of a defunct drive doesnt work you'll need to change the drive. remember in a raid 5 you need min. 3 drives.
Posted on Dec 07, 2007
  • 17 Answers
SOURCE: xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Posted on Nov 06, 2008
  • 13 Answers
SOURCE: server doesnt boot
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
-Chip
Posted on Nov 26, 2008
  • 105 Answers
SOURCE: new install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
Posted on May 26, 2009
inovagent
  • 111 Answers
SOURCE: need x series 226 IBM server drivers
What is is OS? Do you need the drivers for the for the RAID controller? Which variant of the 226 is it? Feel free to contact me through my website on business servers, especially if you're near Rockville, MD
Posted on Oct 28, 2009
NMI ISSUED PRESS ESC TO TURN OFF NMI IN IBM SERVER
dear mugkifa ,
the above error indicates , a non maskable interrupt occurred in your server , there may be a change of malfunction of a hardware ,like add on cards
one more solution in ibm server is disablig the NMI interrupt by using jumper settings (inside motherboard)
see the below mentioned details , may differ with your server series please refer with series on http://www-947.ibm.com/support/entry/portal/docdisplay?brandind=5000008&lndocid=MIGR-5069937
System-board jumpers
The following illustration shows the switches and jumpers on the system board:
migr-5069937_2.gif Note: Any jumper blocks on the system board that are not shown in the illustration are reserved. The following table describes the function of each jumper block:
Jumper Settings CMOS jumper (JP3) Pins 1 and 2: Keep CMOS data (default)
Pins 2 and 3: Clear the CMOS data, which clears the power-on password and administrator password Boot block jumper (JP4) Pins 1 and 2: Normal (default)
Pins 2 and 3: Recover boot block NMI (non-maskable interrupt) switch (SW1) Normal (default): No NMI issued
The NMI button that is on the rear of server, connected to this switch, has been pressed: NMI issued
May 07, 2010 | IBM eserver xSeries 360 8686
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
How to install windows server2003in ibm server x3400
The install is fairly easy. Before you begin make sure if you have SCSI adaptors installed have the drivers for them on hand. If you do not have these drivers you should download them to a 1.4MB floppy disk. When you are ready, put the Windows Server disk in the cd/dvd and reboot the IBM. Follow the instructions on screen and you shoud be fine. From start to finish it should take you about 1 1/2 hours to complete everything.
Good Luck
Franklin
C2Solutions
Jul 21, 2009 | IBM x3400 Server
IBM server dc can't boot due to system32\drivers\pci.sys missing
You mention on boot that the server shows a logical drive of 158GB, which obviously means the server is detecting the drives ok.
Quite often Windows doesn't have the correct drivers to support systems using RAID controllers such as IBM ServerRaid, so this is probably why the setup CD states "No HDD detected, press F3 to reboot". When the Windows Setup CD Boots, it should at some point (on the blue screen) at the bottom of the screen state something like "Press F6 to load additional drivers". If you can get the correct drivers from IBM website, and load them by pressing F6, Windows should be able to see the drives ok. Hopefully it will then be able to successfully repair the error.
May 23, 2009 | IBM eServer xSeries? 206m
Server formatting problem
hi dear
you can get driver from this site
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIGR-56811
put on the floppy drive, just entering when floppy drive asking
oke
Apr 12, 2009 | IBM xSeries 226 Server
I have new ibmx3400 series serv er its not start but shown the green light if i press the power on switch on server and give also the orange color light what can i do i thing this is power problem please...
Just installed the very same server for 1 of our clients. This may sound dumb... however, after pushing the (green) power button - you must *wait* - it seems an inordiante amt of time for the boot to be shown. But should eventually come up!
If not, in warranty call IBM Server support: 8004267378 Make sure you have your mach. type to enter.
Cheers,
gurutim
Mar 17, 2009 | IBM x3400 Server
Xseries 346 wont boot
Apr 02, 2008 | IBM xSeries 346 Server
Server doesnt boot
-Chip
Defunct drive
Dec 06, 2007 | Computers & Internet
IBM eServer xSeries 346 Logo
246 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
