Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Zanussi washing machine
My washing machine has stopped without emptying and i cannot get it to empty, even on the drain cycle.
my whirlpool washer also stops on spin cycle, and water remains in the machine
  • bharris10 Oct 31, 2008
    I have a whirlpool top load washer model #LSC8244BQ0 that stops during the agitation cycle and will not drain or go to the spin cycle.
  • wiscrna Nov 02, 2008
    Stops after agitation. Clicking noise from dial (like its timing), but no action after that
    President:
  • 1,294 Answers
Check your filters first, then the pump. Refer to your manual; or click troubleshooting above.............sure would get some tips.
Posted on Jan 16, 2008
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Front load whirlpool washer wont drain. (ghw9150pw0) I cleaned the trap, ran the spin and drain cycle. It gave me the suds message, but then the load drained fine. I then ran an empty cycle hoping to...
I don't know if this will help you, but we have a Haier HNS1460TVE and this is apparently made by Whirlpool ... we have a similar problem in that if the load is not full it will not spin, it stops at 9 minutes and just gets stuck !!!
We have found that emptying the machine & turning it off and on, with the door shut, resets the machine ... hope that helps you !!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi washing machine, conditioner doesn't empty
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2009 | Zanussi ZWF1430W Front Load Washer
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 16, 2008 | Zanussi FJD1666W Front Load Washer
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
134 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
